This is just the simplest of the attempts made. Hopefully there are clues in there that someone can follow.
On Ubuntu 16.04, 64 bit:
roger@roger-desktop:~$ sudo apt-get install --reinstall ttf-mscorefonts-installer
[sudo] password for roger:
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 0 B/29.5 kB of archives.
After this operation, 0 B of additional disk space will be used.
N: Ignoring file '50unattended-upgrades.ucf-old' in directory '/etc/apt/apt.conf.d/' as it has an invalid filename extension
Preconfiguring packages ...
(Reading database ... 329314 files and directories currently installed.)
Preparing to unpack .../ttf-mscorefonts-installer_3.4+nmu1ubuntu2_all.deb ...
mscorefonts-eula license has already been accepted
Unpacking ttf-mscorefonts-installer (3.4+nmu1ubuntu2) over (3.4+nmu1ubuntu2) ...
Processing triggers for fontconfig (2.11.94-0ubuntu1.1) ...
Processing triggers for update-notifier-common (3.168.2) ...
ttf-mscorefonts-installer: processing...
ttf-mscorefonts-installer: downloading http://downloads.sourceforge.net/corefonts/andale32.exe
Get:1 http://downloads.sourceforge.net/corefonts/andale32.exe [198 kB]
Fetched 198 kB in 2s (66.5 kB/s)
W: Can't drop privileges for downloading as file '/var/lib/update-notifier/package-data-downloads/partial/andale32.exe' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
ttf-mscorefonts-installer: downloading http://downloads.sourceforge.net/corefonts/arial32.exe
Err:1 http://downloads.sourceforge.net/corefonts/arial32.exe
The HTTP server sent an invalid Content-Range header
W: Can't drop privileges for downloading as file '/var/lib/update-notifier/package-data-downloads/partial/arial32.exe' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied)
E: Failed to fetch https://cytranet.dl.sourceforge.net/.../corefonts/the fonts/final/arial32.exe The HTTP server sent an invalid Content-Range header
E: Download Failed
Setting up ttf-mscorefonts-installer (3.4+nmu1ubuntu2) ...
karel
  • 122,292
  • 133
  • 301
  • 332
That's due to a bug in Apt. To install it, open a terminal (press Ctrl+Alt+T) and run:
sudo apt purge ttf-mscorefonts-installer
sudo chown -R _apt:root /var/lib/update-notifier/package-data-downloads/partial
sudo apt install ttf-mscorefonts-installer
sudo chown -R root:root /var/lib/update-notifier/package-data-downloads/partial
Chai T. Rex
  • 5,323
