I have a new Lenovo Thinkpad E560, running Windows 7. I installed Ubuntu 16.10, creating partitions for root, home, tmp, and swap. A partition called "bios_grub" was created automatically.
Now whenever I boot the system it boots to Windows 7. My boot menu does not seem to be from grub, it shows only four items:
Windows
ATAPI CD0 – boots from DVD
ATA HDD0 – does nothing
PCI LAN – does nothing
My question is not "how do I install Ubuntu". I have done that several times, without any major problems. This time, however, although Ubuntu has been installed on my disk, it does not appear in the boot menu.
I booted from an Ubuntu live DVD and ran boot-repair but it tells me it cannot deal with a BIOS boot, only UEFI. So I tried to change the Windows boot to UEFI. The result is no booting system at all, with the following message:
File: \EFI\Microsoft\Boot\BCD
Status: 0xc000000d
Info: An error occurred while attempting the boot configuration data.
When I changed the boot menu back to BIOS Windows worked again. No Ubuntu boot option.
The file \EFI\Microsoft\Boot\BCD exists on the EFI system partition, and the partition is flagged as "boot" and "esp" (shown by gparted). There is no other partion flagged as "boot". The disk is GPT. The Windows partition administration says the partition has status "no errors (EFI system partition)". It is the first partition on the disk.
I see two possible ways to proceed:
(1) Can I change my Windows boot to UEFI, so I can run boot-repair successfully?
(2) Alternatively, is there a way to get a dual boot (grub or whatever) running with BIOS?
Any help is appreciated. Please inform me if there is more information I should provide.
Edit: Output from "sudo lsblk -f":
NAME    FSTYPE    LABEL   …
sda
├─sda1    vfat    SYSTEM_DRV                 …
├─sda2
├─sda3    ntfs    Windows7_OS …
├─sda4    ntfs    Lenovo_Recovery …
├─sda5
├─sda6    swap …
├─sda7    ext4 …
├─sda8    ext4 …
├─sda9    ext4 …
├─sda10   ext4 …
sr0    tso9960    Ubuntu 16.04.1  LTS amd64      … /cdrom
loop0    squashfs         …    /rofs
sudo lsblk -fm additionally gives the following sizes:
sda    931.5G
sda1   100M
sda2   128M
sda3   232.9G
sda4   14G
sda5   95M
sda6   14.9G
sda7   9.3G
sda8   14.9G
sda9   540.2G
sda10  105.1G
I installed Ubuntu 16.10 from a live DVD, which I booted via the second item in my boot menu (ATAPI CD0). How can I "start installer in UEFI mode", as oldfred suggested? If I can do that, maybe it resolves my problem.
Sorry, I cannot answer in a comment (size limitation), so I have to edit my original question.
@ubfan1's hint to change my boot options from "BIOS first" to "UEFI first" solved my problem. I re-installed Ubuntu after changing this, and now I have a Grub menu. – ubfan1, if you re-enter this as an answer rather than a comment I will gladly give you credit.
Renardo
  • 116
