I've been trying to use pipelight to install Flash on Firefox so I can watch HBO Now. I am able to install Widevine and Silverlight without any issues but I get the following error in console when it tries to install Flash:
[install-dependency] ERROR: Downloading of wine-flash-installer failed multiple times. Please check:
[install-dependency]        * that your internet connection is working properly
[install-dependency]        * and that the plugin database is up-to-date. To update it just run:
[install-dependency]            sudo pipelight-plugin --update
[install-dependency]        If this doesn't help then most-likely the download URLs or checksums
[install-dependency]        have changed. We recommend to open a bug-report in this case.
[install-dependency] ERROR: Download of wine-flash-installer failed.
I have found multiple threads online from a couple years back which suggest to update pipelight to v0.2.8 but I am already using v0.2.8.2. I've run --update and --create-mozilla-plugins as well. Does anyone know how I can fix this error or download the necessary installer manually?
(using Ubuntu 16.04, Firefox 50.1.0)
edit; Also, the output of 'sudo pipelight-plugin --update' if it helps:
Resolving bitbucket.org (bitbucket.org)... 2401:1d80:1010::150, 104.192.143.3, 104.192.143.2, ...
Connecting to bitbucket.org (bitbucket.org)|2401:1d80:1010::150|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 29488 (29K) [text/plain]
Saving to: ‘/tmp/tmp.2j7RyqWGg6’
/tmp/tmp.2j7RyqWGg6                     100%[==============================================================================>]  28.80K  --.-KB/s    in 0.03s
2016-12-26 23:56:09 (1.03 MB/s) - ‘/tmp/tmp.2j7RyqWGg6’ saved [29488/29488]
gpg: Signature made Tue 01 Nov 2016 04:29:54 PM EDT using RSA key ID 1434FC73
gpg: Good signature from "Pipelight Dev Team (install-dependency) <webmaster@fds-team.de>"
gpg: WARNING: This key is not certified with a trusted signature!
gpg:          There is no indication that the signature belongs to the owner.
Primary key fingerprint: CF23 08D4 3507 9A77 124E  01A2 83C7 3FB2 1434 FC73
Script dependency-installer is already up-to-date.
Alex
  • 69
Per the comments on the top post (and pipelight.net) it looks like Pipelight has been discontinued so I'm not sure there's a solution.
An alternative, for those without access to another OS, is to install Firefox and Flash with Wine. I find this to work reasonably well.
Alex
  • 69
