26
In the Linux / Unix administration handbook it mentions that you can edit the /etc/inittab file to change the run level. I don't have that file on 10.04. I Googled this and found a tip saying that file had been replaced with /etc/event.d/rc-default - however I don't have that file on my system either.
Have these been deleted or does 10.04 deal with run levels differently?
Braiam
  • 69,112
cwd
  • 1,663
  • 19
  • 24
Yes, it deals with them differently.
To see the current (and previous) runlevel:
runlevel
To switch runlevels:
sudo init $runlevel
For example, to reboot:
sudo init 6
The init you are reading about was replaced by upstart starting with Edgy Eft 6.10; and, one of the programs provided by upstart is its own implementation of init. Here are the docs for 10.04.
To change the default runlevel, use your favorite text editor on /etc/init/rc-sysinit.conf...
sudo vim /etc/init/rc-sysinit.conf
Change this line to whichever runlevel you want...
env DEFAULT_RUNLEVEL=2
Then, at each boot, upstart will use that runlevel.
To See the Current Run Level Command:
$ who -r or $ runlevel
If you want chance the runlevel Command
$ sudo init 1 ( it will take to u single user mode)
This are differnt runlevel you can perform :
0 - System halt; no activity, the system can be safely powered down.
1 - Single user; rarely used.
2 - Multiple users, no NFS (network filesystem); also used rarely.
3 - Multiple users, command line (i.e., all-text mode) interface; the standard runlevel for most Linux-based server hardware.
4 - User-definable
5 - Multiple users, GUI (graphical user interface); the standard runlevel for most Linux-based desktop systems.
6 - Reboot; used when restarting the system.
Premkumar
  • 351
You could also make use of the corresponding target of your desired runlevel. You can check which of the available target your system is running as default using:
systemctl get-default
Supposing the graphical.target is the default, you can further check its definition and detailed information using:systemctl cat graphical.target. There are some target units tailored after the corresponding runlevels. You can find which of them are available on your system by listing them: systemctl list-unit-files -t target Suppose you want to set runlevel 2 as default, you can do this by running:
sudo systemctl set-default runlevel2.target
You should use this with caution and make sure you are not causing any issues running on the inappropriate target.
Normally this is done by explicitly adding a number to the kernel options in the GRUB entry.
Let's say, you want to change default grub entry from default run level (5) to 3:
sudo vim /boot/grub/grub.cfg
Find a place of default boot entry, and have a look at linux line. Might look something like this:
linux   /boot/vmlinuz-3.0.0-13-generic root=UUID=d07e0c99-65ba-4eda-98d8-79693dc79554 ro   quiet splash vt.handoff=7
Add 3 at the end of that line:
linux   /boot/vmlinuz-3.0.0-13-generic root=UUID=d07e0c99-65ba-4eda-98d8-79693dc79554 ro   quiet splash vt.handoff=7 3
Try it out:
sudo reboot
