What is the method to install CryptoTE on 16.04?
Link to the instructions on installing CryptoTE on Ubuntu
Following those instructions I have the following error:
> sudo apt-get update
> sudo apt-get install cryptote
Reading package lists... Done
Building dependency tree
cryptote : Depends: libwxbase2.8-0 (>= 2.8.12.1) but it is not installable
Depends: libwxgtk2.8-0 (>= 2.8.12.1) but it is not installable
Update:
A commenter, M. Becerra, provided me with links to libwxbase2.8-0 and libwxgtk2.8-0. After installing them CryptoTE can be invoked from the Dash but it fails to run. Instead it shows a busy cursor for a few seconds and then the busy cursor disappears. Invoking cryptote from the command line results in the following print.
Fatal Error: Mismatch between the program and library build versions detected.
The library used 2.8 (no debug,Unicode,compiler with C++ ABI 1009,wx containers,compatible with 2.6),
and CryptoTE used 2.8 (no debug,Unicode,compiler with C++ ABI 1002,wx containers,compatible with 2.6).
Aborted (core dumped)
ABI means Application Binary Interface so it appears that the CryptoTE needs to invoke a ABI 1002 library but the library I have is compiled to be a ABI 1009 library.
