I am on Ubuntu 16.04, and was wondering if there is a way to use a P2P file sharing program like Bit Torrent?
I have tried Transmission with no luck, and then installed qBittorrent again with no results.
The torrent does not seem to move and I get the following:
udp://open.demonii.com:1337   Not Working
udp://tracker.leechers-paradise.org:6969   Not Working
udp://zer0day.ch:1337   Not Working
udp://tracker.coppersurfer.tk:6969   Not Working
udp://exodus.desync.com:6969   Not Working
Error
Any troubleshooting help is appreciated.
Thanks.
edwinksl
  • 24,109
A quick and easy way is to use Transmission:
  1. Click the Ubuntu icon in the upper left corner of the screen
  2. Type "Transmission" (something like "torrent" would work as well)
  3. Click the "Transmission BitTorrent Client" icon
Transmission BitTorrent Client in dash
Chai T. Rex
  • 5,323
I use qBittorrent. It's no frills fast and easy, very similar to utorrent for Windows. You can from "GNOME Software". Type qBittorrent and install, or open a terminal and type:
sudo add-apt-repository ppa:qbittorrent-team/qbittorrent-stable
then:
sudo apt update && sudo apt install qbittorrent
Once installed, you can start it from Unity Dash or application menu.
Dave
  • 1,454
