I'm still new to Ubuntu/Linux use
I'm installing Emacs (version 25.1) that I've downloaded source files, uncompressed and extracted the files using tar
It seems I have to use ./configure. Computer works for a while and gives me this result:
checking for X... no
checking for X... true
configure: error: You seem to be running X, but no X development libraries
were found.  You should install the relevant development files for X
and for the toolkit you want, such as Gtk+ or Motif.  Also make
sure you have development files for image handling, i.e.
tiff, gif, jpeg, png and xpm.
If you are sure you want Emacs compiled without X window support, pass
  --without-x
to configure.
I looked in internet about this problem and a reply in a thread says to use:
sudo apt-get build-dep emacs23
and this will install everything needed to compile emac23 package but when I do this I get :
E: Unable to find a source package for emacs25.1
In software and updates screen I've enabled the source code option. I checked in etc/apt/sources.list.d folder and it is empty.
I'm not sure what to do. If everything fails will compiling emacs without x window support cause problems later?
Should I try to manually install x development files, toolkit files,files for image handling. How is how do I do this.
Edit:
So I installed Emacs using pre-built package. used command :
sudo apt-get install emacs
Edit 2:
In 2019 I'm now using VIM editor, so can't address this question now. But if you have an answer feel free to leave below
damadam
  • 2,873
kanr
  • 61
What version of Ubuntu do you have? I downloaded the tar'd source from the gnu emacs site. I ran :
./configure
It told me that I need libXpm and libgif/libungif. I installed libXpm-dev and libgif-dev with :
sudo apt-get install libxpm-dev libgif-dev
After I installed those, I reran configure (./configure), and then I was able to build it.
I now have a binary for emacs in my emacs-25.1/src directory called emacs-25.1.1, and it works.
damadam
  • 2,873
Lee H.
  • 106
This is the command I'm using to install emacs 26.3 on ubuntu 18.04:
$ sudo apt-get install build-essential texinfo-doc-nonfree install-info info libx11-dev libxpm-dev libjpeg-dev libpng-dev libgif-dev libtiff-dev libgtk2.0-dev libncurses5-dev libxpm-dev automake autoconf libgnutls28-dev
For details please see Compile error: checking for libXaw... configure: error: No X toolkit could be found
Please note that I simply had to change libncurses-dev to libncurses5-dev, add texinfo-doc-nonfree install-info info and libgnutls28-dev
