I get this error when trying to install libapache2-mod-php5 on xenial:
fontconfig : PreDepends: dpkg (>= 1.16.1)
Depends: fontconfig-config but it is not going to be installed
libapache2-mod-php5 : Depends: libssl1.0.0 (>= 1.0.0) but it is not going to be installed
Depends: apache2-mpm-prefork (> 2.0.52) but it is not going to be installed or
apache2-mpm-itk but it is not installable
Depends: apache2.2-common but it is not going to be installed
Depends: php5-common (= 5.3.10-1ubuntu3.25) but it is not going to be installed
Depends: ucf but it is not going to be installed
Depends: tzdata but it is not going to be installed
Recommends: php5-cli but it is not going to be installed
libfontconfig1 : Depends: fontconfig-config (= 2.11.94-0ubuntu1.1) but it is not going to be installed
libgtk2.0-0 : Depends: libcairo2 (>= 1.6.4-6.1) but it is not going to be installed
Depends: libpangocairo-1.0-0 (>= 1.28.3) but it is not going to be installed
Depends: libpangoft2-1.0-0 (>= 1.28.3) but it is not going to be installed
Recommends: libgtk2.0-bin
libqt5svg5 : PreDepends: dpkg (>= 1.15.6~)
Depends: libqt5widgets5 (>= 5.3.0) but it is not going to be installed
libuuid1 : Depends: passwd
Recommends: uuid-runtime
The answers to similar questions suggest trying to install the packages manually. But fontconfig, libfontconfig1, libgtk2.0-0, libqt5svg5, and libuuid1 are already installed. So are all the packages named as dependencies of libapache2-mod-php5. So why won't it install?
Edit: I solved the problem by installing php7.0 and libapache2-mod-php7.0 instead, but I'd still like to understand these confusing error messages.
As requested:
$ sudo apt-cache policy libapache2-mod-php5
libapache2-mod-php5:
Installed: (none)
Candidate: 5.3.10-1ubuntu3.25
Version table:
5.3.10-1ubuntu3.25 500
500 http://us.archive.ubuntu.com/ubuntu precise-updates/main amd64 Packages
500 http://security.ubuntu.com/ubuntu precise-security/main amd64 Packages
5.3.10-1ubuntu3 500
500 http://us.archive.ubuntu.com/ubuntu precise/main amd64 Packages
Hmmm...
$ grep precise /etc/apt/sources.list
(no output)
I'm using GIMP 2.6 because 2.8 is heinous garbage. I forget exactly how I installed 2.6, but I think it was similar to this answer. Does this suggest that apt still has precise stuff in its cache, even though I removed the repos from sources.list?
