I just ran:
uname -r
and this came up:
4.4.0-53-generic
Then I did:
sudo apt upgrade
the output was:
The following NEW packages will be installed:
  linux-headers-4.4.0-57 linux-headers-4.4.0-57-generic linux-image-4.4.0-57-generic linux-image-extra-4.4.0-57-generic
But when I run
uname -r
I still get
4.4.0-53-generic
What should I do?
Zanna
  • 72,312
After your first uname -r it listed 4.4.0-53 as the kernel version you last booted with.
When you did sudo apt upgrade it offered to update your disk with newer kernel 4.4.0-57 but you must select Y to upgrade it on disk. You did not say if you did this or not.
When you typed uname -r a second time it still shows 4.4.0-53 as the kernel you booted with because you haven't rebooted yet.
Anyways... Do the upgrade and select Y and then reboot to get the newest kernel booted into RAM and virtual directories /proc, /sys, etc.
apt-get upgrade is restricted to the case where packages are to be replaced by newer versions.
but in your case there are packages be additions, so you should use apt-get dist-upgrade.
For example, 'linux-image-generic- package will update by 'linux-image-4.4.0-57-generic'.
See Here for more information.
