I have a HP pavilion g6 series (32-bit) system. I was using Ubuntu 16.04 LTS and everything was working fine until I downloaded BleachBit and used the app incorrectly. It somehow damaged my Ubuntu badly.
I downloaded an ISO image of 32-bit Xubuntu. I have a 64GB sandisk USB, I copied the ISO image to the USB drive but I have another file on the USB device. I tried to boot my laptop with this USB but nothing appears; my system keeps on starting normally.
I want to install this new iso image but I can't. Is there a way to install it without USB or CD?
Zanna
  • 72,312
There is not a way to install without usb/cd unless you use pxe boot, or a more advanced install.
Copying the iso to the usb drive will delete everything on it. It must be imaged, not copied. Use 'dd if=/path/to/iso of=/dev/sd?' where sd? is the dev path of your usb drive. Wait a while, it will output nothing. Once it returns, the usb will be imaged and you will be able to boot it.
Kyle H
  • 1,064
