Got a faster internet today so decided to test it and ... figured out that I have the same 20-30 Mbps out of 50, when wired.
I tried to play with channels, as I found that there are multiple neighbors running wifi on the same channel. It didn't give any significant and stable result. It could even drop below numbers I mentioned.
I tried to use a router from a provider and also attached another router to it. Both show the same performance. I tried also to play with modes and leave only 802.11n without any significant result either.
EDIT1: Here is a link to the wireless-info output http://paste.ubuntu.com/23671497
EDIT2: Tried to disable 11n, speed dropped 2 times, so didn't help. Didn't notice if swcrypto gives any drawbacks/benefits. I also noticed that Cisco router in 11n only mode works 50% faster and gives me about 30Mbps
##### lspci #############################
01:00.0 Network controller [0280]: Intel Corporation Centrino Wireless-N 2230 [8086:0887] (rev c4)
Subsystem: Intel Corporation Centrino Wireless-N 2230 BGN [8086:4062]
Kernel driver in use: iwlwifi
wlp1s0 IEEE 802.11 ESSID:"F62Q7"
Mode:Managed Frequency:2.437 GHz Access Point: <MAC 'F62Q7' [AC1]>
Bit Rate=43.3 Mb/s Tx-Power=16 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
Link Quality=65/70 Signal level=-45 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:1 Invalid misc:237 Missed beacon:0
So, the question is - if it's possible to achieve higher speed than the current one?
