19
I entered la accidentally instead of ls to view the contents of a directory and it produces exactly the same output as ls...
Why is this? Surely it doesn't make sense to have two commands that do the exact same thing.
TellMeWhy
  • 17,964
  • 41
  • 100
  • 142
6 Answers6
34
la is an alias to ls -A defined in ~/.bashrc file in Ubuntu.
It only shows the same output if you have no hidden files or directories.
ls -A shows hidden files and directories.
Pilot6
  • 92,041
14
la is defined as an alias in Ubuntus ~/.bashrc file together with a few others. la is simply an ls -A as you can see in the following snippet from the ~/.bashrc
# this alias is defined earlier to grant colored output
alias ls='ls --color=auto'
# some more ls aliases
alias ll='ls -alF'
alias la='ls -A'
alias l='ls -CF'
alias li='ls -lF'
Videonauth
  • 33,815
When in doubt, type la.
Bash output:
la is aliased to `ls -la'
Fish output:
la is a function with definition
function la --description 'List contents of directory, including hidden files in directory using long format'
    ls -lah $argv
end
ls is a command, l and la are most likely aliases which make use of the command ls. If you run the command alias you can find all the aliases on your system.
$ alias | grep -E ' l=| la='
This will return all the aliases that match the pattern l=... or la=....
They do not produce the same output in all directories.
Create a dotfile with touch .whatever, then issue both la and ls.
user4556274
  • 5,097
la is an alias for ls -A, as stated by other answers. As such, it can't be used in shell scripts, while ls can.
Your computer has multiple aliased commands. A complete list can be obtained by executing alias. On my machine it prints this:
alias alert='notify-send --urgency=low -i "$([ $? = 0 ] && echo terminal || echo error)" "$(history|tail -n1|sed -e '\''s/^\s*[0-9]\+\s*//;s/[;&|]\s*alert$//'\'')"'
alias egrep='egrep --color=auto'
alias fgrep='fgrep --color=auto'
alias grep='grep --color=auto'
alias l='ls -CF'
alias la='ls -A'
alias ll='ls -alF'
--color=auto means colour will be turned off when not printing directly to STDOUT.
wjandrea
  • 14,504
