There are several threads concerning deactivating encryption by ecryptfs on a home directory. A selection is listed below. All (seem to) suggest that the current home directory will be wiped out by the process of removing encryption.
The output of ecryptfs-setup-private --undo says
In the event that you want to remove your eCryptfs Private Directory setup, you will need to very carefully perform the following actions manually:
- Obtain your Private directory mountpoint $ PRIVATE=
cat ~/.ecryptfs/Private.mnt 2>/dev/null || echo $HOME/Private- Ensure that you have moved all relevant data out of your
$PRIVATEdirectory- Unmount your encrypted private directory
$ ecryptfs-umount-private- Make your Private directory writable again
$ chmod 700 $PRIVATE- Remove $PRIVATE, ~/.Private, ~/.ecryptfs Note: THIS IS VERY PERMANENT, BE VERY CAREFUL
$ rm -rf $PRIVATE ~/.Private ~/.ecryptfs- Uninstall the utilities (this is specific to your Linux distribution)
$ sudo apt-get remove ecryptfs-utils libecryptfs0
Since $PRIVATE is actually /home/user (the directory protected by encryption, please check), the current home directory gets emptied and deleted because of one's own doing through rm -rf $PRIVATE
I noticed one fellow's interesting remark on line 5. Reportedly https://askubuntu.com/a/10049/446253 did not find deleting home necessary, which is a very interesting hint. Making back-ups of data is good in its own right, but it's no immaterial thing if you could remove encryption without manipulating your user home content!
I am not certainly asking to put your own data at risk in place of mine, but could more experienced people judge whether a step 5 like rm -rf ~/.Private ~/.ecryptfs would be sufficient instead?
This could help out people who struggle with full disks to be emptied and cannot resort to network file systems because of encryption, for example.
Sources
How to stop using built-in home directory encryption?
Can you unencrypt / remove encryption from a user home folder?
How to disable encrypted home directory?
