I am trying to compile ffmpeg from sources and create deb package in order to install ffmpeg globally and make it possible to remove it with dpkg -r command.
Here are my commands.
# Installing FFmpeg
cd ~/ffmpeg_sources
wget http://ffmpeg.org/releases/ffmpeg-snapshot.tar.bz2
tar xjvf ffmpeg-snapshot.tar.bz2
cd ffmpeg
PATH="$HOME/bin:$PATH" PKG_CONFIG_PATH="$HOME/ffmpeg_build/lib/pkgconfig" ./configure \
--prefix="$HOME/ffmpeg_build" \
--pkg-config-flags="--static" \
--extra-cflags="-I$HOME/ffmpeg_build/include" \
--extra-ldflags="-L$HOME/ffmpeg_build/lib" \
--bindir="$HOME/bin" \
--enable-gpl \
--enable-libass \
--enable-libfdk-aac \
--enable-libfreetype \
--enable-libmp3lame \
--enable-libopus \
--enable-libtheora \
--enable-libvorbis \
--enable-libvpx \
--enable-libx264 \
--enable-libx265 \
--enable-nonfree
PATH="$HOME/bin:$PATH" make
sudo checkinstall --pkgname=ffmpeg --pkgversion="5:$(date +%Y%m%d%H%M)-git" --backup=no \
--deldoc=yes --fstrans=no --default
hash -r
Everything compiles successfully, deb packages are created but when I try to use ffmpeg I get
ffmpeg: command not found
So that means that ffmpeg still not installed in $PATH directories.
What is wrong with my commands?
