  • ruby -v: ruby 2.2.2p95 (2015-04-13 revision 50295) [x86_64-linux]
  • which ruby: /home/iuser/.rbenv/shims/ruby
  • rails -v: Rails 4.2.3
  • subl -v: Sublime Text Build 3126
  • Ubuntu: Ubuntu 16.04.1 LTS
It doesn't matter from which directory I launch the Sublime Text 3 from, as long as I launch it using subl from terminal, I am able to build any Ruby code, using the Ctrl + B even when the settings are the Tools > Build System > Automatic.
However, when I launch the same Sublime Text 3 from Ubuntu Dash, I am not able to build Ruby Code, and I get the following error:
/bin/bash: ruby: command not found
[Finished in 0.0s with exit code 127]
[shell_cmd: ruby "/home/iuser/Desktop/1.rb"]
[dir: /home/iuser/Desktop]
[path:/home/iuser/bin:/home/iuser/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin]
Even though $PATH returns:
bash: /home/iuser/.rbenv/plugins/ruby-build/bin:/home/iuser/.rbenv/shims:/home/iuser/.rbenv/bin:/home/iuser/bin:/home/iuser/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:
I was able to overcome this by making a custom build system which pointed to the rbenv and then changing the Sublime Text 3 Tools > Build System > MyCustomBuild (http://snakelab.cc/2014/12/10/sublime_3_and_rbenv.html)
My question is:
  1. Why do I need to make a custom build system, and why its not picking up the rbenv just like the Sublime Text 3 which is started from terminal?
  2. How can I make changes so that no matter where I start the Sublime Text 3 from, even if the build system is set to Automatic, it always builds the ruby code?
muru
  • 207,228
Thanks to muru, I was able to fix this issue
Initially I did the configuration in the following manner:
echo 'export PATH="$HOME/.rbenv/bin:$PATH"' >> ~/.bashrc
echo 'eval "$(rbenv init -)"' >> ~/.bashrc
echo 'export PATH="$HOME/.rbenv/plugins/ruby-build/bin:$PATH"' >> ~/.bashrc
source ~/.bashrc
The correct method lies in echo-ing to ~/.profile instead of ~/.bashrc:
echo 'export PATH="$HOME/.rbenv/bin:$PATH"' >> ~/.profile
echo 'eval "$(rbenv init -)"' >> ~/.profile
echo 'export PATH="$HOME/.rbenv/plugins/ruby-build/bin:$PATH"' >> ~/.profile
source ~/.profile
