on Ubuntu 16.10, for some minute after wifi connection, systemd-journal, systemd-resolve and dnsmasq tend to use almost 150% of CPU.
Is this normal?
Is this normal?
Suggested by another Steps of solution
Add the line DNSMASQ_EXCEPT=lo to /etc/default/dnsmasq
sudo nano /etc/default/dnsmasq
Restart dnsmasq via
sudo service systemd-resolved restart
Say Thanks If I helped, It went back to normal and does NOT screw around with other apps, as the previous method DID.
Cheers, Mark
I had the same Problem in 18.04. systemd-resolved and dnsmasq tend to loop. I solved it this way:
Add or uncomment the following line in /etc/default/dnsmasq:
IGNORE_RESOLVCONF=yes
Create your own resolv file (/etc/resolv.personal) to define nameservers. You can use any nameserver here. I took two from OpenNIC.
nameserver 5.132.191.104
nameserver 103.236.162.119
In /etc/dnsmasq.conf add or uncomment the following line:
resolv-file=/etc/resolv.personal
Then restart dnsmasq and disable the default resolver: systemd-resolved.
sudo service dnsmasq restart
sudo systemctl stop systemd-resolved
sudo systemctl disable systemd-resolved
Read man systemd-journald; Read man systemd-resolve; Read man dnsmasq; Read man journalctl.
Check your log files in /var/log/*.
From the little you've said, it looks like a whole bunch of log entries are being made (Investigate why!), and some part of your logging system is trying to resolve "domain names, IPv4 and IPv6 addresses, DNS resource records or services with the systemd-resolved.service(8) resolver service.". (Read man 8 systemd-resolved.service.) This "name resolution" is what's taking the time.
Normal? When Linux runs on everything from Systems-On-Chip to members of the Top 50 Supercomputers, what does "Normal" mean?
