I was wondering if there was any way to hide the disc information message (the one that says X blocks available, X blocks safe or something to that effect. Not sure what that's called.) that I get on start-up. Not that the information isn't helpful, it's just a message which causes unnecessary worry by reminding me of when my previous hard drive was failing. So, like, is there a way to either hide this behind a fancy start-up animation, or even have it buried within the wall of text that just confirms the computer's capabilities (again, not sure what it's called. It's the one that just says [OK] USB Keyboard and stuff like that).
Asked
Active
Viewed 339 times
Phoxxent
- 43
To prevent the display of text information as Ubuntu boots you will need to edit your grub here /etc/default/grub.
Change :
GRUB_CMDLINE_LINUX_DEFAULT= #shows text but not splash screen
to:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" #no text but shows splash screen
I am assuming that you have it set to the first example, hence the information your seeing.
See here for a comprehensive explanation.
George Udosen
- 37,534
