This results from installing kubuntu-desktop failed for unmet dependencies. I guess I lost my kubuntu desktop after mysql 5.6 installation. I recovered the desktop back by installing kubuntu-desktop and akonadi-backend-mysql which depends on mysql 5.5.
When I got the desktop back, the previously installed MySQL 5.6 was gone and these two files are not found in the directory /var/run/mysqld/.
/var/run/mysqld/mysqld.pid
/var/run/mysqld/mysqld.sock
I still have the configuration files
/etc/mysql/my.conf
/etc/mysql/conf.d/my5.6.conf
and the databases in the data directory
/var/lib/mysql/
I will have to install MySQL 5.6, but my concern is that akonadi-backend-mysql may not work with 5.6. I found that kind of bug reported. Here are some of my details:
sudo apt-cache depends akonadi-backend-mysql
[sudo] password for sithu:
|Depends: mysql-server-core-5.5
Depends: mariadb-server-core-5.5
|Depends: mysql-client-core-5.5
Depends: mariadb-client-core-5.5
Depends: libqt4-sql-mysql
Recommends: akonadi-server
Breaks: akonadi-server
Replaces: akonadi-server
sithu@sithu-kubuntu:~$ sudo apt-cache policy akonadi-backend-mysql
akonadi-backend-mysql:
Installed: 1.12.1-0ubuntu1.2
Candidate: 1.12.1-0ubuntu1.2
Version table:
*** 1.12.1-0ubuntu1.2 0
500 http://security.ubuntu.com/ubuntu/ trusty-security/universe i386 Packages
100 /var/lib/dpkg/status
1.12.1-0ubuntu1 0
500 http://mm.archive.ubuntu.com/ubuntu/ trusty/universe i386 Packages
sithu@sithu-kubuntu:~$ sudo apt-get install mysql-server-5.6
Reading package lists... Done
Building dependency tree
mysql-server-5.6 : Depends: mysql-client-5.6 (>= 5.6.33-0ubuntu0.14.04.1) but it is not going to be installed
Depends: mysql-server-core-5.6 (= 5.6.33-0ubuntu0.14.04.1) but it is not going to be installed
sithu@sithu-kubuntu:~$ sudo apt-get install mysql-client-5.6 mysql-client-core-5.6
mysql-client-core-5.6 : Breaks: mysql-client-core-5.5 but 5.5.53-0ubuntu0.14.04.1 is to be installed
This results unmet dependencies: mysql-client-core-5.6 : Breaks: mysql-client-core-5.5 but 5.5.53-0ubuntu0.14.04.1 is to be installed.
So, my question is
- Is it safe to install MySQL 5.6 against
akonadi-backend-mysql? - How to install it without breaking my desktop again?
My distro is Kubuntu 14.04 LTS.
sithu@sithu-kubuntu:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 14.04.1 LTS
Release: 14.04
Codename: trusty
