Our corporate has its own mailserver and I want to send mail to it from command line. I've install smtp and configure it.
Configuration in /etc/ssmtp/ssmtp.conf
root=username@symantric.com
mailhub=mailserver.symantric.com:25
rewriteDomain=symantric.com
hostname=gtmpc
FromLineOverride=YES
AuthUser=username
AuthPass=password
UseSTARTTLS=YES
UseTLS=YES
Configuration in /etc/ssmtp/revaliases
root:username@symantric.com:mailserver.symantric.com:25
mainuser:username@symantric.com:mailserver.symantric.com:25
When i run command:
echo "Test message from Linux server using ssmtp" | sudo ssmtp -vvv username@symantric.com
Output:
[<-] 220 mailserver.symantric.com ESMTP Postfix
[->] EHLO gtmpc
[<-] 250 DSN
[->] STARTTLS
[<-] 220 2.0.0 Ready to start TLS
[->] EHLO gtmpc
[<-] 250 DSN
[->] AUTH LOGIN
[<-] 334 VXNlcm5hbWU6
[->] Z2F5YXRyaS5wYXRlbA==
[<-] 334 UGFzc3dvcmQ6
[<-] 535 5.7.8 Error: authentication failed: authentication failure
ssmtp: Authorization failed (535 5.7.8 Error: authentication failed: authentication failure)
Output of /var/log/syslog:
Dec 21 10:41:12 gtmpc sSMTP[23619]: Creating SSL connection to host
Dec 21 10:41:12 gtmpc sSMTP[23619]: SSL connection using RSA_AES_128_CBC_SHA1
Dec 21 10:41:12 gtmpc sSMTP[23619]: Authorization failed (535 5.7.8 Error: authentication failed: authentication failure)
