I remember this started when I was trying to install wine. I tried following the instructions on the page, that involved adding the i386 architecture, and installing the winehq-devel package, with the --install-recommends option.
Except it didn't work at the time, and it gave me some errors:
winehq-devel : Depends: wine-devel (= 2.0~rc1~ubuntu16.04.1)
If I try to install it, I get the same error with wine-devel-i386:
 wine-devel-i386:i386 : Depends: libgphoto2-6:i386 (>= 2.5.9) but it is not going to be installed
                        Depends: libgstreamer-plugins-base1.0-0:i386 (>= 1.0.0) but it is not going to be installed
                        Depends: libgstreamer1.0-0:i386 (>= 1.4.0) but it is not going to be installed
                        Depends: libldap-2.4-2:i386 (>= 2.4.7) but it is not going to be installed
                        Depends: libxml2:i386 (>= 2.9.0) but it is not going to be installed
                        Recommends: libosmesa6:i386 (>= 10.2~) but it is not going to be installed
                        Recommends: libsane:i386 (>= 1.0.24) but it is not going to be installed
                        Recommends: libxslt1.1:i386 (>= 1.1.25) but it is not going to be installed
I tried searching for answers regarding the broken packages and tried a bunch of stuff:
dpkg --configure -a
apt-get clean
apt-get autoclean
apt-get install -f
apt-get upgrade
apt-get dist-upgrade
(not by this order, but I found different solutions that mentioned them)
dpkg --get-selections | grep hold
doesn't give me any packages either.
I also tried istalling synaptic to check the broken packages, which didn't show me anything.
I also tried installing with aptitude, it gives me options, if I understand how it works, but it either doesn't install the package, or it requires me to remove 1500+ packages, which doesn't seem like a solution to me.
I kinda gave up on it, until I tried to install nvidia drivers. I removed the old version and when I tried to install the 375:
 nvidia-375 : Depends: lib32gcc1 but it is not going to be installed
              Depends: libc6-i386 but it is not going to be installed
I get this again. And if I try to install it individually, with apt-get install libc6-i386 :
 libc6-i386 : Depends: libc6 (= 2.23-0ubuntu3) but 2.23-0ubuntu4 is to be installed
Is there anything I could do to try and fix this, or should I just reinstall and get it over with?
msk
  • 31
It appears that at some point you were attempting to install the development version of wine which some users had difficulty with.
I believe you may have missed the part in the instructions that state "If you have previously installed a Wine package from another repository, please remove it and any packages that depend on it (e.g., wine-mono, wine-gecko, winetricks) before attempting to install the WineHQ packages, as they may cause dependency conflicts."
This being the case I recommend that you
1) remove wine completely
2) Remove any other packages that depend on it (e.g., wine-mono, wine-gecko, winetricks) with sudo apt-get remove wine-mono wine-gecko winetricks
3) Decide whether to install the stable Ubuntu repository package version 1.6 at last check (which I use) or the winehq staging or development package keeping in mind that development packages are under development and aren't likely to be very stable.
3a) To install the stable Ubuntu Repository package issue the command sudo apt-get install wine
3b) To install the staging version issue the following commands in order If and only if your system is 64 bit, enable 32 bit architecture (if you haven't already): sudo dpkg --add-architecture i386
Regardless:
sudo add-apt-repository ppa:wine/wine-builds
sudo apt-get update
sudo apt-get install --install-recommends winehq-staging
3c) To install the development version issue the following commands in order If and only if your system is 64 bit, enable 32 bit architecture (if you haven't already): sudo dpkg --add-architecture i386
Regardless:
sudo apt-get update
sudo apt-get install --install-recommends winehq-devel
I recommend that you use the stable version from the Ubuntu repositories unless you have a good reason to do otherwise (like you are a developer/tester assisting the wine team)
I so, you should know that users of the staging branch should file bugs here, and can now submit test reports to the AppDB
A great place to go for further assistance with wine or to get involved with the project is https://wiki.winehq.org/Main_Page If you visit it would be a good idea to read the FAQ.
Note: As a rule of thumb, I highly recommend current backups prior to making any changes to your operating system. It makes putting things back to normal far easier. With total power comes total responsibility.
Elder Geek
  • 36,752
