I'm a Linux novice experimenting with setting up a DNS cache server on a Pine64 on Ubuntu 16.04. I'm trying to set up a static IP-address with a a local Bind9 DNS-server. I've followed this great tutorial, and looked at several others.
However, I'm having trouble with getting the changes in /etc/resolv.conf to stick. /: When I reboot, the settings in /etc/network/interfaces are not written to /etc/resolv.conf.
This is my /etc/network/interfaces:
# interfaces(5) file used by ifup(8) and ifdown(8)
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
# Disable wlan1 by default (8723bs has two intefaces)
iface wlan1 inet manual
# Loopback interface
auto lo
iface lo inet loopback
# The primary network interface
auto eth0
iface eth0 inet static
        address 192.168.0.18
        netmask 255.255.255.0
        gateway 192.168.0.1
        dns-nameservers 192.168.0.18
        dns-search green.intra
This is my /etc/default/bind9:
# run resolvconf?
RESOLVCONF=yes
# startup options for the server
OPTIONS="-4 -u bind"
From those two files, I was under the impression that the /etc/resolv.conf should become this (automatically, upon booting):
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
#     DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 192.168.0.18
search green.intra
...but instead it becomes this:
nameserver 83.255.255.1
nameserver 83.255.255.2
search home
If I add my desired settings to /etc/resolv.conf, everything works as I expect, until I reboot.
What am I doing wrong?
Edit: I have RTFM in trying to figure this out:
https://help.ubuntu.com/14.04/serverguide/dns-troubleshooting.html
https://help.ubuntu.com/12.04/serverguide/network-configuration.html
https://help.ubuntu.com/14.04/serverguide/dns-configuration.html
Edit: ifup and ifdown fail: As suggested in the answer to the proposed duplicate question, using service networking restart might not be reliable in this situation. Instead, I tried the following:
ubuntu@pinex:~$ sudo ifdown -v eth0
Reading directory /etc/network/interfaces.d
Parsing file /etc/network/interfaces.d/eth0
ifdown: interface eth0 not configured
and:
ubuntu@pinex:~$ sudo ifup -v eth0
Configuring interface eth0=eth0 (inet)
/bin/run-parts --exit-on-error --verbose /etc/network/if-pre-up.d
run-parts: executing /etc/network/if-pre-up.d/wpasupplicant
/sbin/dhclient -1 -v -pf /run/dhclient.eth0.pid -lf /var/lib/dhcp/dhclient.eth0.leases -I -df /var/lib/dhcp/dhclient6.eth0.leases eth0
Internet Systems Consortium DHCP Client 4.3.3
Copyright 2004-2015 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/eth0/36:c9:e3:f1:b8:05
Sending on   LPF/eth0/36:c9:e3:f1:b8:05
Sending on   Socket/fallback
DHCPREQUEST of 192.168.0.18 on eth0 to 255.255.255.255 port 67 (xid=0x79b015c0)
DHCPACK of 192.168.0.18 from 192.168.0.1
RTNETLINK answers: File exists
bound to 192.168.0.18 -- renewal in 5280 seconds.
/bin/run-parts --exit-on-error --verbose /etc/network/if-up.d
run-parts: executing /etc/network/if-up.d/000resolvconf
run-parts: executing /etc/network/if-up.d/bind9
run-parts: executing /etc/network/if-up.d/openssh-server
run-parts: executing /etc/network/if-up.d/upstart
run-parts: executing /etc/network/if-up.d/wpasupplicant
/bin/ip addr add 192.168.0.18/255.255.255.0 broadcast 192.168.0.255       dev eth0 label eth0
Failed to bring up eth0.
... which led me to the answer (see below).
Reyhn
  • 121
As stated in my question, the configuration is accurate according to the Ubuntu documentation. However, ifdown and ifup did not work. After half a day of googling around, I gathered enough clues to find a solution.
TL;DR;
Comment out (or remove) the lines from /etc/network/interfaces.d/eth0 that originally was:
auto eth0
iface eth0 inet dhcp
The long answer:
I'm sorry I cannot provide an explanation as to why I had this problem. I know too little of Linux. /: The problem seems to be that resolvconf, which is triggered when booting (I think), was unable to correctly update /etc/resolv.conf because it found the same interface twice: once in /etc/network/interfaces.d/eth0 and once in my custom configuration /etc/network/interfaces.
Restarting the network service gave me this:
ubuntu@pinex:~$ sudo service networking restart
Job for networking.service failed because the control process exited with error code. See "systemctl status networking.service" and "journalctl -xe" for details.
ubuntu@pinex:~$ systemctl status networking.service
● networking.service - Raise network interfaces
   Loaded: loaded (/lib/systemd/system/networking.service; enabled; vendor preset: enabled)
  Drop-In: /run/systemd/generator/networking.service.d
           └─50-insserv.conf-$network.conf
   Active: failed (Result: exit-code) since Mon 2016-12-19 13:59:48 CET; 10s ago
     Docs: man:interfaces(5)
  Process: 2433 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=1/FAILURE)
  Process: 2428 ExecStartPre=/bin/sh -c [ "$CONFIGURE_INTERFACES" != "no" ] && [ -n "$(ifquery --read-environm
 Main PID: 2433 (code=exited, status=1/FAILURE)
Dec 19 13:59:47 pinex ifup[2433]: DHCPACK of 192.168.0.18 from 192.168.0.1
Dec 19 13:59:47 pinex ifup[2433]: RTNETLINK answers: File exists
Dec 19 13:59:47 pinex dhclient[2446]: bound to 192.168.0.18 -- renewal in 4214 seconds.
Dec 19 13:59:47 pinex ifup[2433]: bound to 192.168.0.18 -- renewal in 4214 seconds.
Dec 19 13:59:48 pinex ifup[2433]: RTNETLINK answers: File exists
Dec 19 13:59:48 pinex ifup[2433]: Failed to bring up eth0.
Dec 19 13:59:48 pinex systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
Dec 19 13:59:48 pinex systemd[1]: Failed to start Raise network interfaces.
Dec 19 13:59:48 pinex systemd[1]: networking.service: Unit entered failed state.
Dec 19 13:59:48 pinex systemd[1]: networking.service: Failed with result 'exit-code'.
I remember seeing something about the /etc/network/interfaces.d/eth0 when googling around. When commenting out those lines, restarting the network service worked fine. However, the /etc/resolv.conf was still the same as before...
I had to do the following:
ubuntu@pinex:~$ sudo resolvconf -u
/etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /run/resolvconf/resolv.conf
ubuntu@pinex:~$ sudo rm /etc/resolv.conf
ubuntu@pinex:~$ sudo ln -s /run/resolvconf/resolv.conf /etc/resolv.conf
That updated the /etc/resolv.conf to my expected values! After a reboot of the device, the file was automatically properly populated!
I hope this is of help to someone else as well! And, if anyone can explain the problem, that would be appreciated. (:
Reyhn
  • 121
