I have several partitions, mainly, two NTFS for Windows(one for the system, another to share data with Ubuntu), one EXT4 (for "/") and another swap.
I have the next error when trying to save a file using Chrome or Firefox (insuficient permissions).
If I try to create a file with nautilus, it is the same (even when I open Nautilus as root!!).
This is my fstab file:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sda5 during installation
UUID=3b0db9ae-b58b-47d8-ae09-73cc4dca4a39 /               ext4    errors=remount-ro 0       1
# /media/c was on /dev/sda2 during installation
UUID=64004A63004A3BF4 /media/c        ntfs    defaults,umask=007,gid=46 0       0
# /media/d was on /dev/sda3 during installation
UUID=01D19238D33F4D20 /media/d        ntfs    defaults,umask=007,gid=46 0       0
# swap was on /dev/sda6 during installation
UUID=50f1d3ed-b1e3-49ec-9508-20ccf93921bb none            swap    sw              0       0
The problem I have is that I cannot write in both (/media/c nor /media/d partitions) from Ubuntu!! It is very upsetting, because I didn't find anyone with the same kind of problem.
I have a Dual-Boot computer with Windows10 (job purposes) and Ubuntu Gnome 16.10
Thanks for the help!
zapotec
  • 113
Try changing your mounts in /etc/fstab from:
to:
#UUID=64004A63004A3BF4 /media/c        ntfs    defaults 0       0
UUID=01D19238D33F4D20 /media/d        ntfs    defaults 0       0
Note: I commented out the mounting of the C: drive because it's not a good idea to modify the C: partition from Ubuntu... Windows doesn't like it.
Then reboot Ubuntu.
If you must have the C: drive mounted, you'll need to do this in Windows:
  • open the Power control panel
  • click on change what the power buttons do
  • click on change options that are unavailable
  • uncheck fast start
  • close the Power control panel
  • open an administrative command prompt window
  • type powercfg /h off
  • type chkdsk /f c:
  • approve that chkdsk runs at next boot time
  • type chkdsk /f d: (if you'd like to check the D: drive)
  • reboot Windows
heynnema
  • 73,649
I had the same problem. I used this to solve it:
sudo umount /dev/sda2
sudo ntfsfix /dev/sda2
reboot
Eliah Kagan
  • 119,640
