I installed KDE and now I want to remove it. Using the following command: sudo apt-get purge kubuntu-desktop
But instead of removing it, I get the following error:
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
After running the sudo dpkg --configure -a
I tried again to run the purge command and this was the output:
You might want to run 'apt-get -f install' to correct these:
kde-telepathy-minimal : Depends: kde-config-telepathy-accounts (>= 15.04.0) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I ran the apt-get -f install with no packages but that didn't fix the issue. The output of this command is:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following additional packages will be installed:
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
Need to get 0 B/137 kB of archives.
After this operation, 825 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 364670 files and directories currently installed.)
Preparing to unpack .../kde-config-telepathy-accounts_4%3a15.12.3-0ubuntu1_amd64.deb ...
Unpacking kde-config-telepathy-accounts (4:15.12.3-0ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/kde-config-telepathy-accounts_4%3a15.12.3-0ubuntu1_amd64.deb (--unpack):
trying to overwrite '/usr/share/accounts/services/google-im.service', which is also in package account-plugin-google 0.12+16.04.20160126-0ubuntu1
Processing triggers for libc-bin (2.23-0ubuntu5) ...
