I'm new to ubuntu. Recently I installed ubuntu. Hard drive partitioning for ubuntu was done during the installation process. Now I can't go to hard drives giving an error message that it can't mount hard drives. I went through online help and it was said to restart windows after booting from GRUB. But from GRUB even though I select windows 10 loader windows does not boot. Basically I have two problems.
Asked
Active
Viewed 920 times
You can try the boot-repair tool. Open terminal and type the following to install.
sudo add-apt-repository ppa:yannubuntu/boot-repair
sudo apt-get update
sudo apt-get install -y boot-repair
Then run boot-repair by typing boot-repair in terminal and then select the Recommended repair option. When repair is finished, note the URL (paste.ubuntu.com/XXXXX) that appeared on a paper, then reboot and check if you recovered access to your Windows, if not comment with the URL.
For more details visit https://help.ubuntu.com/community/Boot-Repair
