I have a 3TB usb harddisk that I wish to switch between windows, but most of the time Ubuntu 12.04 server. But whatever I try, it can't be correctly recognized by both systems.
The last closest try I have done by now is: [I believe i] format the drive in windows and add a drive letter. Then unplug the drive and plug it in the Ubuntu system. Then run the command: mount ntfs-3g /dev/sdb1 /media/usb1.
But that gives 2 issues:
Most important one, files I add to the drive in windows aren't there on Ubuntu, and files I add on Ubuntu are missing in windows.
The other issue is; the drive isn't recognized in Ubuntu (no /dev/sdb1 exists, however /dev/sdb does). No UUID is present for sdb1. However mounting manually with /dev/sdb1 is no problem. But adding it to fstab (I tried to mount it with /dev/sdb1 instead of UUID) gives me the following error on system startup:
HDIO_GET_IDENTITY failed for '/dev/sdb'
Can't find an issue on the web. looks like it should work at once without problems. Can someone put me in the correct direction?
some extra info:
fdisk -l
Disk /dev/sdb: 3000.6 GB, 3000592977920 bytes 255 heads, 63
sectors/track, 364801 cylinders, total 5860533160 sectors Units =
sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512
bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/sdb1 1 4294967295 2147483647+ ee GPT
blkid
/dev/sda1: UUID="ec280792-e09f-4957-bb9e-5fc2cca2a297" TYPE="ext4"
/dev/sda5: UUID="bf95d0b6-dd74-44b2-b7b5-9f2d64a07aa4" TYPE="swap"
parted -l
Error: /dev/sdb: unrecognised disk label
lshw
*-scsi:2
physical id: 5
bus info: usb@1:2
logical name: scsi6
capabilities: emulated scsi-host
configuration: driver=usb-storage
*-disk
description: SCSI Disk
product: External USB 3.0
vendor: Toshiba
physical id: 0.0.0
bus info: scsi@6:0.0.0
logical name: /dev/sdb
version: 0201
serial: 76B67345
capabilities: partitioned partitioned:dos
configuration: ansiversion=6
*-volume UNCLAIMED
description: EFI GPT partition
physical id: 1
bus info: scsi@6:0.0.0,1
capacity: 2047GiB
capabilities: primary nofs
