I am using the (excellent) readline (version 6.3, default [non-vi] mode) library from within my own program, running in a Terminal window (on a PC). There is a problem when there is previous output not terminated by newline when readline() is called.
#include <stdio.h>
#include <readline/readline.h>
void main(void)
// Previous output from some other part of application
// which *may* have output stuff *not* terminated with a '\n'
printf("Hello ");
fflush(stdout);
char *in = readline("OK> ");
So the line looks like:
Hello OK> <caret here>
If you type a small number of characters (up to 5?) and then, say, Ctrl+U (may be others) to delete your input so far it all seems well --- readline() moves the caret back to just after its own prompt. However, try typing, say:
123456 <Ctrl+U>
Now it deletes back into the Hello, leaving just Hell on the line, followed by the caret.
I need one of two possible solutions:
This does look like a bug, now that I have realised it depends on how many characters are typed on the line where it goes wrong. Any fix/workaround?
Alternatively, is there a
readlinelibrary call I could make which would tell me what position/column the caret is at before I invokereadline()? Then at least I could recognise the fact that that I am at the end of an existing line and output a\nso as to position myself at the start of a new line first.
P.S.
Is this an OK place to ask about readline programming under Ubuntu or should I be posting at stackoverflow.com?
