I am looking for a terminal command to shutdown without having to write down my password and without installing any extra programs.
As when clicking the shutdown button, why it is not asking me for the password and a program like gnome-pie that shutdown without asking me for the password and without confirmation.
I want this command as I am a Java programmer and I want to make use of it.
enzotib
  • 96,093
Black Block
  • 5,139
You will need to add command alias for all related command as follows:
Cmnd_Alias SHUTDOWN_CMDS = /sbin/shutdown, /sbin/halt, /sbin/reboot
and after that you need to add a user specification as follows at the end of /etc/sudoers file
<your username> ALL=(ALL) NOPASSWD: SHUTDOWN_CMDS
You will need root permissions to write to sudoers file.
This is from ubuntu community documentation at https://help.ubuntu.com/community/Sudoers#Shutting_Down_From_The_Console_Without_A_Password
binW
  • 13,194
You could make your 'sudo' work without a password.
visudo
Add to end of the file...
your_user_name ALL = NOPASSWD: ALL
Save. Log out. Log in. Now you can shutdown/reboot without a password. But I think you want this link instead: How can I make shutdown not require admin password?.
Assuming you want to run the commands under an X session:
Under UPower (Ubuntu 10.04+)
to suspend:
dbus-send --print-reply --system --dest=org.freedesktop.UPower /org/freedesktop/UPower org.freedesktop.UPower.Suspend
to hibernate:
dbus-send --print-reply --system --dest=org.freedesktop.UPower /org/freedesktop/UPower org.freedesktop.UPower.Hibernate
You can find more info at: https://wiki.ubuntu.com/DebuggingGNOMEPowerManager
Li Lo
  • 16,382
