I am trying to setup mysql-cluster-gpl-7.1.17-linux-i686-glibc23.tar.gz on ubuntu 10.04 server for the past 3 weeks and not successful yet.
The links I followed are:
http://stepbysteparticles.com/index.php?option=com_content&view=article&id=48&Itemid=54
http://cyrenity.wordpress.com/2010/08/12/howto-setup-mysql-cluster-beginners-tutorial/
http://tech.jocke.no/2011/03/13/mysql-cluster-how-to-with-load-balancing-failover/
http://www.lod.com/whitepapers/mysql-cluster-howto.html
http://blog.rimuhosting.com/2011/07/06/building-database-clusters-with-mysql/
All the configurations in the above links are almost same with some slight changes and I just gave a try of all if any works but none.
I already made a post in serverfault but I am still could not able to make it work.
I always come back here if nothing works out after many tries and now I am.
Also I am not understanding whether mysql-server or mysql-client need to be installed along with mysql-cluster else mysql-cluster alone is enough for running mysqld on SQL nodes. In my case the setup is 3 nodes=(data1+sql1 + data2+sql2 + mgmt node).
Frequent errors:
/etc/init.d/mysql.server start
Output:
Starting MySQL
* Couldn't find MySQL manager (/usr/bin/mysqlmanager) or server (/usr/bin/mysqld_safe)
I even tried copying /usr/local/mysql/bin/* to /usr/bin but still no use as it was telling . * Manager of pid-file quit without updating file. while trying to start!
While trying to start mysql daemon on data/sql node
cd /usr/local/mysql
./bin/mysqld_safe --user=mysql --defaults-file=/etc/my.cnf &
Output:
[1] 2338
root@web2:/usr/local/mysql# 111208 15:53:47 mysqld_safe Logging to syslog.
111208 15:53:47 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
111208 15:53:47 mysqld_safe mysqld from pid file /var/lib/mysql/web2.pid ended
[1]+ Done ./bin/mysqld_safe --user=mysql --defaults-file=/etc/my.cnf
Anybody take up and help me here please?. Anybody clarify if there is any problem with ubuntu or with cluster config?. I have to implement this on cloud servers once I am successful.
Thank you!
Update:1
Now on SQL/Data nodes I have had already removed mysql-server and mysql-client which I generally install as a basic package of any fresh installation. I removed them by running following command and on both of the nodes only mysql-cluster is available which I could not able to setup:
apt-get remove mysql-client mysql-client-5.1 mysql-client-core-5.1 mysql-common mysql-server mysql-server-5.1 mysql-server-core-5.1
Update:2
I have fixed the issues I had. Now I have the following things left to be done.
What is the best method to Add/Remove
mgmt,SQL/DATAnodes being online?EDIT: I tried mysql docs for adding nodes online but confused and didn't work unless I shutdown all the nodes and remove the logs under
/var/lib/mysql-clusteron all the nodes.What additional configurations should I include in my
my.conffile for best performance tuning likeDataMemoryandIndexMemory, if anybody using for production, can recommend or paste it here please?
Update:3
How to convert all the table engines of the database to NDB which are having foreign keys also?
EDIT: I found a script for converting all the table engines but all the tables of my database are not converted as for the error: ERROR 1217 (23000) at line 11: Cannot delete or update a parent row: a foreign key constraint fails
Is there a way to possess both the features of NDB & InnoDB with cluster and multi-master replication with no risk(down time)?
