Just need some help on this. Windows 10 killed my computer, I think it was updating or something but it killed my computer anyway. The only thing I could get up was my bios and recovery mode. I tried all things in the recovery mode, like Repair and Recover using Media (I made a Windows 10 disc using the media creation tool on the Microsoft website) long story short, nothing worked. I then decided to try Ubuntu and I managed to get a live version working and then decided to go the whole 9 yards and install it. The install wiped out everything but I had resigned myself to losing all my old docs and things. I really like Ubuntu and didn't really want to go back to Windows but there was one program which would not work with WINE so I decided to try to create a dual boot system with Windows 10. I did get Windows 10 on eventually but it wiped out Ubuntu. I tried again. This time I installed Ubuntu after Windows 10 and both OS are working fine now. The problem is when booting up. When I boot up I get 4 options:
* Ubuntu
  Advanced options for Ubuntu
  Windows Boot Manager (on /dev/sda1)
  System setup
If I boot into Ubuntu, everything is fine but if I try to boot into Windows I get the message:
/EndEntire
filepath: /ACPI(ao341do,0)/PCI(2,1f)/Sata(1,0,0)/HD(1,800,82000,7e8d39a0fa133f49,2,2)/File(\EFI\Microsoft\Boot)/File(bootmgfw.efi)/EndEntire
error: cannot load image
Press any key to continue
When I press a key it then takes me back to the menu. The only way I can get Windows to load is to go into 'System setup' which takes me into the Bios screen and from there I have to change the boot order so that the windows boot manager is first. That means from then on the computer always boots into Windows and to get into Ubuntu I have to go into Bios when I first turn on the computer and change the boot order again. Any ideas would be greatly appreciated. I am new to Ubuntu but am reasonably confident around computers and don't mind using the Terminal.
Turning off secure boot worked! But as added info for anyone who follows along on the path.... I have a Phoenix SecureCore Tiano bios setup and secure boot is greyed out. You need to set a Supervisor Password in the Security tab. I saved the setting first and went into Windows, I then restarted the computer, went back into Bios, it will ask for the password. I could then disable the secure boot.
chaskes
  • 15,536
