When I click on Steam I get this error:
Couldn't set up Steam data - please contact technical support.
I am getting the same error as this person. Here is a link to question:
Steam cannot set up steam data
I then tried the top answer provided in the link above and show what I encountered below, but first I am going to show you the error I get when I try to run steam in the terminal.
Here is error encountered in the terminal when I try run steam in terminal.
johnwawryk@SteamMachine:~$ steam
Repairing installation, linking /home/johnwawryk/.steam/steam to /home/johnwawryk/.local/share/Steam
rm: cannot remove '/home/johnwawryk/.steam/steam': Is a directory
Setting up Steam content in /home/johnwawryk/.local/share/Steam
Here is the top answer I talked about earlier that was in the link provided above:
Then I try what @Denilson Sá Maia (it was his idea for another person facing the same error) said to do and nothing happens. Here is link: Steam cannot set up steam data
  • mv ~/.steam/steam/* ~/.local/share/Steam/
  • rmdir ~/.steam/steam
  • ln -s ../.local/share/Steam ~/.steam/steam
  • rm -rf ~/.steam/bin
When I did it in terminal:
johnwawryk@SteamMachine:~$ mv ~/.steam/steam/* ~/.local/share/Steam/
mv: cannot move '/home/johnwawryk/.steam/steam/appcache' to '/home/johnwawryk/.local/share/Steam/appcache': Directory not empty
mv: cannot move '/home/johnwawryk/.steam/steam/userdata' to '/home/johnwawryk/.local/share/Steam/userdata': Directory not empty
johnwawryk@SteamMachine:~$ rmdir ~/.steam/steam
rmdir: failed to remove '/home/johnwawryk/.steam/steam': Directory not empty
johnwawryk@SteamMachine:~$ ln -s ../.local/share/Steam ~/.steam/steam
johnwawryk@SteamMachine:~$ rm -rf ~/.steam/bin
Here is a history of the commands I used.
  • 1 nm-tool
  • 2 sudo lshw -C network
  • 3 nm-tool
  • 4 lsb_release
  • 5 lsb_release -a
  • 6 $ sudo add-apt-repository ppa:ubuntu-wine/ppa
  • 7 sudo add-apt-repository ppa:ubuntu-wine/ppa
  • 8 sudo apt-get install wine1.7 winetricks
  • 9 sudo add-apt-repository ppa:ubuntu-wine/ppa
  • 10 sudo add-apt-repository ppa:wine-1.7.7/ppa
  • 11 sudo add-apt-repository ppa:ubuntu-wine/ppa
  • 12 cd desktop
  • 13 cd DESKTOP
  • 14 sudo dpkg -i wine-1.7.7.deb
  • 15 sudo add-apt-repository ppa:ubuntu-wine/ppa
  • 16 sudo apt-get update
  • 17 sudo apt-get install wine1.7 winetricks
  • 18 sudo add-apt-repository ppa:ubuntu-wine/ppa
  • 19 sudo apt-get install ca-certificates
  • 20 apt-cache policy nvidia-current
  • 21 sudo nvidia-xconfig
  • 22 sudo apt-get install steam
  • 23 run sudo apt-get install gdebi-core
  • 24 sudo apt-get install gdebi-core
  • 25 sudo add-apt-repository ppa:graphics-drivers/ppa
  • 26 sudo apt-get update
  • 27 sudo apt-get install nvidia-367
  • 28 steam steam://run/325610
  • 29 run wine
  • 30 sudo run wine
  • 31 chmod +x /usr/bin/winetricks
  • 32 sh winetricks
  • 33 sh winetricks
  • 34 su
  • 35 mv winetricks /usr/bin/
  • 36 wget http://winetricks.org/winetricks
  • 37 wine "c:\program files\steam\steam.exe"
  • 38 mv ~/.steam/steam/* ~/.local/share/Steam/
  • 39 rmdir ~/.steam/steam
  • 40 ln -s ../.local/share/Steam ~/.steam/steam
  • 41 rm -rf ~/.steam/bin
  • 42 run steam
  • 43 $ mv ~/.steam/steam/* ~/.local/share/Steam/
  • 44 cd ~
  • 45 rm -rf .steam
  • 46 cd ~
  • 47 rm -rf .steam
  • 48 cd ~
  • 49 rm -rf .steam
  • 50 mv ~/.steam/steam/* ~/.local/share/Steam/
  • 51 rmdir ~/.steam/steam
  • 52 ln -s ../.local/share/Steam ~/.steam/steam
  • 53 rm -rf ~/.steam/bin
  • 54 mv ~/.steam/steam/* ~/.local/share/Steam/
  • 55 rmdir ~/.steam/steam
  • 56 ln -s ../.local/share/Steam ~/.steam/steam
  • 57 rm -rf ~/.steam/bin
  • 58 History 50
  • 59 history 10
  • 60 history 40
  • 61 MESA_GL_VERSION_OVERRIDE=4.3 MESA_GLSL_VERSION_OVERRIDE=430 %command%
  • 62 mv ~/.steam/steam/* ~/.local/share/Steam/
  • 63 rmdir ~/.steam/steam
  • 64 ln -s ../.local/share/Steam ~/.steam/steam
  • 65 rm -rf ~/.steam/bin
  • 66 mv ~/.steam/steam/* ~/.local/share/Steam/
  • 68 ln -s ../.local/share/Steam ~/.steam/steam
  • 69 rm -rf ~/.steam/bin
  • 70 mv ~/.steam/steam/* ~/.local/share/Steam/
  • 71 rmdir ~/.steam/steam
  • 72 ln -s ../.local/share/Steam ~/.steam/steam
  • 73 rm -rf ~/.steam/bin
  • 74 steam steam
  • 75 mv ~/.steam/steam/* ~/.local/share/Steam/
  • 76 rmdir ~/.steam/steam
  • 77 ln -s ../.local/share/Steam ~/.steam/steam
  • 78 rm -rf ~/.steam/bin
  • 79 steam steam
  • 80 history 10
  • 81 history 50
  • 82 steam steam://run/325610
  • 83 mv ~/.steam/steam/* ~/.local/share/Steam/
  • 85 ln -s ../.local/share/Steam ~/.steam/steam
  • 86 rm -rf ~/.steam/bin
  • 87 history 70
  • 88 history 1000
Note that I am not a Steam user, so all the commands below have not been tested. They should work, based on what you wrote in your question, but I cannot guarantee it.
Here's the core of the issue:
You are getting these two errors because both directories exist:
  • /home/johnwawryk/.steam/steam/appcache
  • /home/johnwawryk/.local/share/Steam/appcache
Same for the userdata directory:
  • /home/johnwawryk/.steam/steam/userdata
  • /home/johnwawryk/.local/share/Steam/userdata
Problem is, I have no idea which directories contains valuable data, and which can be deleted.
I suppose userdata contains saved games? Just in case, here are commands to save the contents of both directories in tar files:
tar -cf ~/old-steam-userdata.tar ~/.steam/steam/userdata
tar -cf ~/new-steam-userdata.tar ~/.local/share/Steam/userdata
Once the tar files have been created in your Home directory (you can check their content with the file explorer), remove the old directories:
rm -Rf ~/.steam/steam
And then you need to run this command again:
Adrien Beau
  • 1,976
