I am trying to install php5-imap but I get the error that dependancies are missing. But they are not!
The error message:
Reading package lists... Done
Building dependency tree
 php5-imap : Depends: phpapi-20090626
dpkg -l | grep php returns this:
ii  libapache2-mod-php5                  5.5.37+dfsg-1+deprecated+dontuse+deb.sury.org~precise+1 server-side, HTML-embedded scripting language (Apache 2 module)
ii  php-http                             1.4.1-1                                                 PHP PEAR module for HTTP related stuff
ii  php-pear                             5.5.37+dfsg-1+deprecated+dontuse+deb.sury.org~precise+1 PEAR - PHP Extension and Application Repository
ii  php5                                 5.5.37+dfsg-1+deprecated+dontuse+deb.sury.org~precise+1 server-side, HTML-embedded scripting language (metapackage)
ii  php5-cli                             5.5.37+dfsg-1+deprecated+dontuse+deb.sury.org~precise+1 command-line interpreter for the php5 scripting language
ii  php5-common                          5.5.37+dfsg-1+deprecated+dontuse+deb.sury.org~precise+1 Common files for packages built from the php5 source
ii  php5-curl                            5.5.37+dfsg-1+deprecated+dontuse+deb.sury.org~precise+1 CURL module for php5
ii  php5-dev                             5.5.37+dfsg-1+deprecated+dontuse+deb.sury.org~precise+1 Files for PHP5 module development
ii  php5-gd                              5.5.37+dfsg-1+deprecated+dontuse+deb.sury.org~precise+1 GD module for php5
ii  php5-imagick                         3.3.0-1+deb.sury.org~precise+2                          Provides a wrapper to the ImageMagick library
ii  php5-json                            1.3.9-1+deb.sury.org~precise+3                          JSON module for php5
ii  php5-mcrypt                          5.5.37+dfsg-1+deprecated+dontuse+deb.sury.org~precise+1 MCrypt module for php5
rc  php5-mysql                           5.5.7+dfsg-1+sury.org~precise+1                         MySQL module for php5
ii  php5-mysqlnd                         5.5.37+dfsg-1+deprecated+dontuse+deb.sury.org~precise+1 MySQL module for php5 (Native Driver)
ii  php5-sqlite                          5.5.37+dfsg-1+deprecated+dontuse+deb.sury.org~precise+1 SQLite module for php5
ii  pkg-php-tools                        1.21+deb.sury.org~precise+1                             various packaging tools and scripts for PHP packages
From the reading I have done, phpapi is part of php-cgi, php-cli and other packages that I have installed.
I also found that php5-fpm is reporting a similar error except with php5-common which is clearly in the list of installed packages.
Any thoughts?
schworak
  • 981
After going around and around trying to figure this out, it ultimately ended up being an old repository. I removed it and the current one picked up all the required upgrades. A little painful to find.
schworak
  • 981
