choz@Choz-Liu:~$ sudo apt-get -f install vagrant
Reading package lists... Done
Building dependency tree
vagrant : Depends: bsdtar but it is not going to be installed
choz@Choz-Liu:~$ sudo apt-get install bsdtar
bsdtar : Depends: libarchive13 (= 3.1.2-11build1) but     3.1.2-11ubuntu0.16.04.2 is to be installed
There appears to be an open bug for this: https://bugs.launchpad.net/ubuntu/+source/vagrant/+bug/1503565
User Matthew Giassa (mgiassa) from that page has a potential workaround:
Matthew Giassa (mgiassa) wrote on 2016-10-07:
Recently encountered this issue on Ubuntu 16.04.1 on 4.4.0-38-generic #57-Ubuntu SMP.
Seems the build label in
libarchive13is either incorrect, orbsdtaris expecting the wrong version.I was able to fix this via:
apt-get download bsdtar mkdir temp_out dpkg-deb -R
bsdtar_3.1.2-11build1_amd64.deb temp_out
# Modify the "control file in temp_out/DEBIAN, changed version from "3.1.2-11build1" to "3.2.1-2~ubuntu16.04.1." Save, close.
dpkg-deb -b temp_out FIXED_bsdtar.deb
sudo dpkg -i ./FIXED_bsdtar.deb
Afterwards, I was able to successfully install and use vagrant via: "sudo apt-get install vagrant". The only downside to this approach is I'll eventually have to resolve this manually when the bsdtar package is actually fixed.
This probably isn't great as a long-term solution, so you may want to just download vagrant for the moment until the bug is patched.
- Download bsdtar suited for Debian 16.04 (mainly for libarchive13 in U16.04): https://packages.ubuntu.com/xenial/amd64/bsdtar/download - wget -P /tmp http://security.ubuntu.com/ubuntu/pool/universe/liba/libarchive/bsdtar_3.1.2-11ubuntu0.16.04.3_amd64.deb
- Install it locally: - apt install /tmp/bsdtar_3.1.2-11ubuntu0.16.04.3_amd64.deb
- Then vagrant can be installed: - apt install vagrant
    - 36,890
- 56
- 97
- 151
