I've looked at other answers regarding this issue but none of them had the same configuration I have so this is new although related to other posts.
I had a dual boot Windows 7 and Ubuntu. What was a bit different than typical is that I had 2 physically separate HDs. The first one had GRUB and Ubuntu, the second one had Windows 7 only. The advantage I had with this setup is that I could physically remove the Ubuntu hard drive and then Windows 7 would boot up normally none the wiser that it used to be booted from GRUB.
After doing a Windows 10 upgrade, things changed. GRUB with Ubuntu hard drive in place still works but if I pull out Ubuntu hard drive, now Windows 10 boot fails with the message GRUB recovery command prompt.
So somehow the Windows 10 upgrade did something to the boot record of the Windows hard drive. I had thought that when I installed GRUB on the Ubuntu hard drive that it only affected Ubuntu hard drive and not the Windows 7 boot disk. Maybe that wasn't true and what was there got corrupted by Windows 10 upgrade.
So now the Windows hard drive has some aspects of GRUB on it that are now corrupted.
Suggestions on how to fix the Windows 10 boot?
Windows 10 corrupted GRUB. Your best solution is to use Ubuntu installation media to reinstall GRUB (best bet is to run boot-repair).
