Using Intel AC 8260, subsystem 0010 (included in lspci below).
I installed ubuntu 16.10 on my new clevo P775DM3-G Laptop yesterday and wifi was working. Well i had to turn bluetooth off, then wifi showed networks, connect to one of them and then turn bluetooth on back and everything worked.
I put machine to sleep and in the morning today, opening it back everything was jumbled (distorted display and keys not working) so had to hard reset and now wifi does not work any more - does not detect any network around. How do i get it back up ?
uname -r
4.8.0-30-generic
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 16.10
Release:        16.10
Codename:       yakkety
For lshw (The wireless reads disabled, that should be of concern ? ):
sudo lshw -C network
  *-network
       description: Ethernet interface
       product: Killer E2400 Gigabit Ethernet Controller
       vendor: Qualcomm Atheros
       physical id: 0
       bus info: pci@0000:6d:00.0
       logical name: enp109s0
       version: 10
       serial: 80:fa:5b:3a:e9:2b
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm pciexpress msi msix bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=alx duplex=full ip=192.168.0.2 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:122 memory:dc400000-dc43ffff ioport:d000(size=128)
  *-network DISABLED
       description: Wireless interface
       product: Wireless 8260
       vendor: Intel Corporation
       physical id: 0
       bus info: pci@0000:70:00.0
       logical name: wlp112s0
       version: 3a
       serial: a4:34:d9:ee:3e:69
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=iwlwifi driverversion=4.8.0-30-generic firmware=22.361476.0 latency=0 link=no multicast=yes wireless=IEEE 802.11
       resources: irq:124 memory:dc100000-dc101fff
For lspci:
lspci -vnn | grep -A 10 -B 10 -i wifi
        Memory at dc200000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: <access denied>
        Kernel driver in use: nvme
        Kernel modules: nvme
70:00.0 Network controller [0280]: Intel Corporation Wireless 8260 [8086:24f3] (rev 3a)
        Subsystem: Intel Corporation Dual Band Wireless-AC 8260 [8086:0010]
        Flags: bus master, fast devsel, latency 0, IRQ 124
        Memory at dc100000 (64-bit, non-prefetchable) [size=8K]
        Kernel driver in use: iwlwifi
        Kernel modules: iwlwifi
For rfkill:
rfkill list
0: hci0: Bluetooth
        Soft blocked: yes
        Hard blocked: no
2: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
Edit 1: I definitely think this is something to do with the failed suspend-resume. I tried suspend resume again and it froze like the last time. However i pressed Ctrl-Alt-F1 followed by Ctrl-Alt-F7 (I used to do this on 14.04 when desktop used to freeze like every couple of hrs with Nvidia 860M to get it to unfreeze again) and after 2 min it recognised the Ctrl-F1 the screen went blank, and then after more 2 min the Ctrl-F7 got it back and everything worked and i logged in. The wifi was enabled and detected connections once more. To confirm (out of habit) i suspended & resumed once again, same problem, pressed Ctrl-Alt-F1 followed by Ctrl-Alt-F7, but this time it froze for good and after 10 min, did a hard reset. Now back to square one - wifi no longer works, lshw shows it's disabled like before :( . Don't know if this is related: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1566302/comments/123
Also here is the requested dmesg: http://paste.ubuntu.com/23625894/
And here is my current graphics card in case it helps anyone figure out what's wrong:
lspci -vnn | grep -A 10 -B 10 -i "\(nvidia\)\|\(vga\)"
    Kernel driver in use: snd_hda_intel
    Kernel modules: snd_hda_intel
00:1f.4 SMBus [0c05]: Intel Corporation Sunrise Point-H SMBus [8086:a123] (rev 31)
    Subsystem: CLEVO/KAPOK Computer Sunrise Point-H SMBus [1558:7705]
    Flags: medium devsel, IRQ 255
    Memory at 2ffff24000 (64-bit, non-prefetchable) [size=256]
    I/O ports at f000 [size=32]
    Kernel modules: i2c_i801
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP106M [GeForce GTX 1060] [10de:1c60] (rev a1) (prog-if 00 [VGA controller])
    Subsystem: CLEVO/KAPOK Computer Device [1558:7706]
    Flags: bus master, fast devsel, latency 0, IRQ 122
    Memory at db000000 (32-bit, non-prefetchable) [size=16M]
    Memory at 90000000 (64-bit, prefetchable) [size=256M]
    Memory at a0000000 (64-bit, prefetchable) [size=32M]
    I/O ports at e000 [size=128]
    [virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
    Kernel driver in use: nvidia
    Kernel modules: nvidiafb, nouveau, nvidia_370, nvidia_370_drm
01:00.1 Audio device [0403]: NVIDIA Corporation Device [10de:10f1] (rev a1)
    Flags: bus master, fast devsel, latency 0, IRQ 17
    Memory at dc080000 (32-bit, non-prefetchable) [size=16K]
Edit 2: After downloading and installing a fresh copy of firmware as asked by @chili555, here is the new dmesg: http://paste.ubuntu.com/23625981/
(The problem still exists)
In your paste, we see a microcode (firmware) error. We wonder if your firmware file is corrupted. Let's download and install a fresh copy. From the terminal with a working internet connection:
wget http://mirrors.kernel.org/ubuntu/pool/main/l/linux-firmware/linux-firmware_1.162_all.deb
sudo dpkg -i linux*.deb
Reboot and let us see a new paste:
dmesg | grep iwl
This page suggests that the firmware for kernel versions 4.3 and newer is the -16 version. Your driver loads -22. Let's experiment by renaming -21 and -22 to try to load -16 and see if it helps.
cd /lib/firmware
sudo mv iwlwifi-8000C-21.ucode  iwlwifi-8000C-21.bak
sudo mv iwlwifi-8000C-22.ucode  iwlwifi-8000C-21.bak
Reboot and let us have a paste.
dmesg | grep iwl
chili555
  • 61,330
So after Edit 1 and 2 in the question i started looking into different directions and finally found this: https://askubuntu.com/a/608897/542532
Taking a hint from there i just executed
:~$ nmcli r wifi off && nmcli r wifi on
and now wifi seems to be back :)
I'll still wait for sometime to see if this does indeed solve it.
Edit: This was only temporary and the problem reappeared after reboot - see @chili555's answer, that's turned out to be far more useful.
Follow these commands:
sudo service network-manager restart
then
sudo ip link set wlp112s0 up
Try to check your logs by runnning sudo journalctl and you should see what happened between it working and stopping.
Add the -b argument to get the output of the current boot only. What you want to see is network manager, which you can view by entering journalctl -u NetworkManager
You can also display kernel messages with the -k argument, and if your hardware is very new, you could try different kernels to understand if it changes the behaviour of network manager. Kernel 4.9 is out, check how to install it here: http://ubuntuhandbook.org/index.php/2016/12/install-linux-kernel-4-9-ubuntu-linux-mint/
dinnerisserved
  • 187
  • 13
