Possible Duplicate:
How to replace GRUB with Windows NT Bootloader?
Using Windows and Ubuntu, I got a black screen with white letters and just three options: "Start Windows", "Start Ubuntu" or "Windows recovery".
Now I installed Ubuntu on an extra drive and get a purple window with a whole bunch of options that I dont need, want or don't even know what the do,
Does someone knows how to help me or how to get the old bootloader back, without uninstalling Ubuntu.
Yakke
What you are seeing is a different bootloader. When you were using Wubi Ubuntu was installed within Windows and the Windows bootloader was used to choose between which operating system you wished to boot into
Now that you have installed Ubuntu onto a different drive a different bootloader, Grub2, has been installed. There is no need to worry that you have broken anything :)
You now will have a few more options when you start your computer, though they may at first glance seem a bit more complicated than the simple Ubuntu or Windows options.
The items and order of the menu may vary slightly on your system but should be basically the same.
  • The first option on the list in the picture above is the normal boot into Ubuntu option
  • The second is to boot into Ubuntu in recovery mode
  • The previous Linux versions option allows you to boot into Ubuntu using an older version of the kernel which can be useful in a rare occasion in which an update causes problems
  • The memtest options allow you to check your RAM for errors
  • And finally you should have an option to boot into Windows (there may also be a further option to boot into Windows in recovery mode)
coversnail
  • 6,406
