I have installed Ubuntu 16.04 LTS along with Windows 7.
Though the installation worked fine,I am unable to do Internet from there.
I do Internet using D-Link Modem where the system requirements are Ubuntu 10.04 or higher.
So it should be compatible with mine,but why is not being detected ?
I have run the command lsusb and I have found it has been listed as D-Link Corp.
Please suggest some remedies.
I did go the networking icon,set the mobile broadband option and set the APN of the mobile operator and operator as Vodafone Connect,but still it's not detected .
EDITS
lsusb
Bus 002 Device 009: ID 2001:a407 D-Link Corp.
On removing modem
dmesg -w gives
[ 1063.191885] usb 2-1.3: Product: D-Link DWP-157
[ 1063.191889] usb 2-1.3: Manufacturer: D-Link,Inc
[ 1063.191894] usb 2-1.3: SerialNumber: 531399703353630
[ 1063.192657] usb-storage 2-1.3:1.0: USB Mass Storage device detected
[ 1063.192843] scsi host12: usb-storage 2-1.3:1.0
[ 1064.190463] scsi 12:0:0:0: CD-ROM HSPA USB SCSI CD-ROM 6225 PQ: 0 ANSI: 0 CCS
[ 1064.193317] sr 12:0:0:0: [sr1] scsi3-mmc drive: 0x/0x caddy
[ 1064.195881] sr 12:0:0:0: Attached scsi CD-ROM sr1
[ 1064.196297] sr 12:0:0:0: Attached scsi generic sg2 type 5
[ 1064.447249] ISO 9660 Extensions: Microsoft Joliet Level 3
[ 1064.448975] ISOFS: changing to secondary root
[ 1165.250481] usb 2-1.3: USB disconnect, device number 9
On plugging again:
dmesg -w
[ 1250.773650] usb 2-1.3: new high-speed USB device number 10 using ehci-pci
[ 1250.867819] usb 2-1.3: New USB device found, idVendor=2001, idProduct=a407
[ 1250.867830] usb 2-1.3: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[ 1250.867836] usb 2-1.3: Product: D-Link DWP-157
[ 1250.867841] usb 2-1.3: Manufacturer: D-Link,Inc
[ 1250.867845] usb 2-1.3: SerialNumber: 531399703353630
[ 1250.868612] usb-storage 2-1.3:1.0: USB Mass Storage device detected
[ 1250.868812] scsi host13: usb-storage 2-1.3:1.0
[ 1251.867201] scsi 13:0:0:0: CD-ROM HSPA USB SCSI CD-ROM 6225 PQ: 0 ANSI: 0 CCS
[ 1251.869953] sr 13:0:0:0: [sr1] scsi3-mmc drive: 0x/0x caddy
[ 1251.870493] sr 13:0:0:0: Attached scsi CD-ROM sr1
[ 1251.870854] sr 13:0:0:0: Attached scsi generic sg2 type 5
[ 1252.147458] ISO 9660 Extensions: Microsoft Joliet Level 3
[ 1252.148686] ISOFS: changing to secondary root
On plugging the modem:
udevadm monitor -u
monitor will print the received events for:
UDEV - the event which udev sends out after rule processing
UDEV [1250.415969] add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3 (usb)
UDEV [1250.428842] add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0 (usb)
UDEV [1250.433148] add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/host13 (scsi)
UDEV [1250.437686] add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/host13/scsi_host/host13 (scsi_host)
UDEV [1251.408929] add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/host13/target13:0:0 (scsi)
UDEV [1251.409064] add /devices/virtual/bdi/11:1 (bdi)
UDEV [1251.414972] add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/host13/target13:0:0/13:0:0:0 (scsi)
UDEV [1251.423177] add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/host13/target13:0:0/13:0:0:0/bsg/13:0:0:0 (bsg)
UDEV [1251.423899] add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/host13/target13:0:0/13:0:0:0/scsi_device/13:0:0:0 (scsi_device)
UDEV [1251.425856] add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/host13/target13:0:0/13:0:0:0/scsi_generic/sg2 (scsi_generic)
UDEV [1251.529367] add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/host13/target13:0:0/13:0:0:0/block/sr1 (block)
UDEV [1251.636974] change /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/host13/target13:0:0/13:0:0:0/block/sr1 (block)
ADDED
Look for default devices ... product ID matched
Found devices in default mode (1)
Access device 004 on bus 002
Error opening the device. Abort
Please guide me here by giving some steps.
