To show the output from the last boot, you can still use the command dmesg.
However, Ubuntu 16.04 (in fact all Ubuntus >=15.04) use systemd which has a logging daemon, journald and an interface with highly flexible access to logged data: journalctl. You can see a log of the last boot equivalent to dmesg:
journalctl -k
From journalctl man page:
-k, --dmesg Show only kernel messages. This implies -b and adds the match "_TRANSPORT=kernel"
all dmesg output in the last 2 hours
journalctl -k --since "2 hours ago"
all of the journal since last boot
journalctl -b
list boots in the journal
journalctl --list-boots
to set up persistent logging, you need to configure journald - by default its log is written non-persistently to /run/systemd/journal (a binary file - no use trying to read it) and no data is available before the current boot. To set up persistent logging, edit the file /etc/systemd/journald.conf and uncomment the line #Storage=auto and change auto to persistent. Use your favourite text editor or
sudo sed -i.bak 's/#Storage=auto/Storage=persistent/' /etc/systemd/journald.conf
Then you must restart the service (or reboot)
sudo systemctl restart systemd-journald
Having enabled persistent logging, you will in future be able to use the full functionality of journalctl for example, to see information from the boot before the current one
journalctl -b -2
See the relevant page of the wonderful <3 Arch Wiki <3 for further tips and tricks on using journalctl
