I made a script that displays a notificaiton whenever I unplug the charger. I made the script to run by udev by making a rule in rules.d. The problem is the script run fine but the notification didn't show up. So far I know that the script requires the address of the display server, here is what my rule and script looks like.
export DISPLAY=:0
export XAUTHORITY=/home/user/.Xauthority
/usr/bin/notify-send --urgency=critical -i face-cool "Charger removed"
zenity --info --text 'Happy New Year'
Here is the rule that I created
SUBSYSTEM=="power_supply", ENV{POWER_SUPPLY_STATUS}=="Discharging", RUN+="/home/user/alertchargerremoved.sh"
Is there any other way to notify myself when the charger is removed, like instead of notification which doesn't require the X server? Do you have any other ideas, how can accomplish this thing?
I have this worked for me before:
ACTION=="remove", KERNEL=="sd?", ENV{ID_PART_TABLE_TYPE}!="", RUN+="/usr/bin/sudo -u username DISPLAY=:0 notify-send 'Unsafe Remove' '<b><i>Your long message</b></i>' -i /usr/share/icons/gnome/48x48/emotes/face-worried.png -t 10000"
From: Alert the user when they unsafely unplug an USB thumb drive
So use sudo to run notify-send as same user (Not as root)
/usr/bin/sudo -u username notify-send ...
user.dz
  • 49,176
