Very similar to the problems in I can neither open nor uninstall Steam (Ubuntu 16.04 LTS), I get this when i run "steam" in terminal:
Running Steam on ubuntu 16.10 64-bit
STEAM_RUNTIME is enabled automatically
/bin/bash: /home/tom/.local/share/Steam/ubuntu12_32/steam-runtime/amd64/lib/x86_64-linux-gnu/libtinfo.so.5: no version information available (required by /bin/bash)
grep: symbol lookup error: grep: undefined symbol: pcre_jit_stack_alloc
Installing breakpad exception handler for appid(steam)/version(1474415843)
libGL error: unable to load driver: i965_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: i965
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
I tried the tips to delete the links to libgcc_s.so.1 and libstdc++.so.6, and to run the command as
LD_PRELOAD='/usr/$LIB/libstdc++.so.6' DISPLAY=:0 steam
to no avail.
Also, just tried
sudo apt-get install steam:i386
based on a small aside tip about 16.10 in a thread about 16.04, same errors after install.
Tom Mercer
  • 1,748
  • 20
  • 38
Have you tried the solution found here - post #6: https://forum.manjaro.org/t/cannot-start-steam/1677
find ~/.steam/root/ -name "libgpg-error.so*" -print -delete
JDMcMillian
  • 1,632
