In Dia, I can add a flowchart box, then add text inside it, and then format the text using properties:
dia
I can align the text horizontally (i.e. left, center, right) inside the box - but i don't see an option to align the text vertically (i.e. top, center, bottom) inside the box. This is on Dia 0.97.2.
Is there a way to align text vertically in a flow/text box in Dia?
EDIT: It can somewhat be achieved by adding carriage return/line feed/Enters either before or after the text (and also controlling the text padding) - but I was wandering if there was a built in function...
sdbbs
  • 1,684
  • 19
  • 27
Grouping a Box- and Text object after custom alignment, is that a solution you already think about. Or using a different Box object like a UML Class object, it seems you can add text in the top, middle and button of that box, see 4.2.7 in the provided link.
Murmulodi
  • 727
