20
I have a 16.04 server on Digital Ocean that lists this when I ssh into it...
 * Documentation:  https://help.ubuntu.com
 * Management:     https://landscape.canonical.com
 * Support:        https://ubuntu.com/advantage
7 packages can be updated.
7 updates are security updates.
I have run apt-get update and apt-get upgrade many times and it has not gone away.
After I run the upgrade I see this as the last line...
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
Joff
  • 514
Since your using ubuntu 16.04 the following should fix it:
sudo apt full-upgrade
But if you prefer the Ubuntu 14.04 way then:
sudo apt-get dist-upgrade
If the two commands don't work you should talk to digital ocean about it.
Hope that helps.
George Udosen
  • 37,534
It is possible your /var/lib/update-notifier/updates-available file did not refresh after your last update.
If you want to set this manually:
sudo su # Needed to acquire permissions.
/usr/lib/update-notifier/apt-check --human-readable >/var/lib/update-notifier/updates-available
exit    # to get out of sudo
Note that /var/lib/update-notifier/updates-available is set with 0600 for permissions for the user & group 'root', which prevent you from simply sudo-ing the apt-check command to rewrite it.
Use the dist-upgrade command, which will perform upgrades that require changing dependencies, adding or removing new packages if necessary. This will handle a set of upgrades which may have been kept back by apt-get upgrade:
sudo apt-get update
For more information see What is "dist-upgrade" and why does it upgrade more then "upgrade" ?
Liso
  • 15,677
First of all the message
says that there are 4 packages not upgraded. I guess these are related to a newer kernel and can be upgraded with
apt-get full-upgrade
Besides that the message
is not calculated every time you login so it might be outdated.
jsalatas
  • 431
