Using ubuntu 16, updates settings on check every day + download and install automatically. Please, could you tell me how to check if the updates have been installed? Thanks.
NicolasSmith
  • 1,031
You can use two methods here to check if you have any updates pending which would suggest updates were not install and need to be.
Steps:
  1. from dash type software updater and select it
  2. from terminal run sudo apt update
In the first one it would check and tell you if any updates are required.
In the second one it will check to see if your repositories are up to date and tell you if any packages needs updating, then if so you may update using:
sudo apt dist-upgrade
To see the history of your updates:
less /var/log/apt/history.log
Hope that helps.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
George Udosen
  • 37,534
