I'm trying to extract the MAC address for a wireless card then insert it into a bash script as a VAR variable with an incremental change. So..
$ ifconfig wlan1 | grep HWaddr
wlan1     Link encap:Ethernet  HWaddr XX:xx:XX:xx:XX:xx
Now I need to command line extract just the XX:xx:XX:xx:XX:xx and add it to the script with a +1 VAR . Which seems pretty straight forward if I can extract just the XX:xx:XX:xx:XX:xx from the grep above. (ie How to increment a variable in bash? )
Can anyone see a roadblock to adding a MAC address as a variable in a bash script? ie without bash thinking the MAC is a string calculation or erroneous command ?
doubt
  • 121
It may be easier to read the MAC from the appropriate file within the sys filesystem. If you call your variable mymac, then:
$ mymac=$(cat /sys/class/net/wlan1/address)
Should work
$ echo "mymac"
XX:xx:XX:xx:XX:xx
It would be possible to increment the value of the last digits with a bit of variable manipulation. This will only work if they are both digits with a value of 98 or less. The following example uses an assumed MAC of 52:1c:53:8b:8f:77.
$ endpair=${mymac##*:}
$ ((endpair++))
$ newmac="${mymac%:*}:${endpair}"
$ echo "Hooray $mymac is now $newmac"
Hooray 52:1c:53:8b:8f:77 is now 52:1c:53:8b:8f:78
Arronical
  • 20,241
This post on Stack Overflow provides a portable solution (it'll work on Unix, generally, not just Ubuntu), and should provide resiliency if the output format of ifconfig changes (or if it's deprecated/removed and you decide to switch to a different tool).
ifconfig wlan1 | grep -o -E '([[:xdigit:]]{1,2}:){5}[[:xdigit:]]{1,2}'
John N
  • 337
You need to add more commands for extracting only the MAC Address.
I suggest you use awk and print only the last column, example:
ifconfig wlan1 | grep HWaddr | awk '{ print $5 }'
This command will show only XX:xx:XX:xx:XX:xx, awk print $5 split lines by spaces.
If you want add this result in bash variable, you need apply this command:
myVarName=$(ifconfig wlan1 | grep HWaddr | awk '{ print $5 }')
Then, you use this content with $myVarName.
echo $myVarName
XX:xx:XX:xx:XX:xx
George Udosen
  • 37,534
