I have some problem with Ubuntu on my brand new win10 Asus laptop, I am new to Linux, so really need your help.
About my laptop: Win10 64bit, i7, 8GB, 128G SSD + 1TB HDD, Nvidia 950M graphic card, brand new, no personal apps/files.
Before installation I encountered a problem booting from usb drive, the Ubuntu 5 point loading page freezes at loading. And then I used UUI to re-do the usb drive and then it passes.
I installed Ubuntu on the 1TB HDD with 30GB root, 300G home and 16GB swap. Leaving Win10 on the 128GSSD (dual boot). Installation process is smooth, but right after install, I reboot the laptop and it freezes at Ubuntu loading (the purple gradient blank screen before the text loading page) There is nothing I can do, so I force the laptop to shut down and then restart.
And then it is like I can only get into Ubuntu every other time, 1 out of 2 times it will stuck at loading, the gradient purple blank screen before text loading show up.
When I get into Ubuntu, the laptop fan seems to be always running at the maximum speed, so I googled some fan control advice. First I followed this tutorial and did:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi=!Windows 2012"
Persistent High-Fan Speed Ubuntu 14.04
but the problem is not solved, so I installed the Laptop Mode Tools as recommended here on ubuntuhandbook.org
And then I just can't get into Ubuntu and get the error message (the fan is still running fast):
tpm_crb MSFT0101:00: can't request region for resource [mem 0xfed400B0-0xfed40fff]
I managed to get to the root from grub menu, and removed laptop mode tools and gksu, and when I reboot the error message is still there but I can get into Ubuntu. But still stuck at loading page almost every other time.
And then I got frustrated and completely removed Ubuntu partition. Now I wanted to give it another try but when I try to boot from usb, it gets stuck at loading page again, almost every time (5 points loading page).
So, why does it always freeze at the loading page (the 5 points indicator page when I boot from usb) (the purple gradient blank screen before the text loading page after installation)? How can I solve the fan problem?
Maark
Had same issue. It was connected with skylake processor architecture. After A LOT OF tries found out that installing ubuntu mate 16.04(not .10) with nvidia-prime solves the issue.
Elmir
