This is second time I get segmentation fault error when I try to run GhostScript on any PDF file with pdfwrite
First time it was my previous Ubuntu 11.04 distro, which afterwards I completely remove (not because of gs), format my drive etc, and then install 11.04 again
I don't know what could be the problem. I work with GS a lot, and now all of a sudden I start getting this errors on any file, like something went wrong with this package or some of it's dependencies.
I searched Synaptic history if there maybe some recent update could cause GS crippling but there was nothing
I reported problems in the past (at least two times) on GS Launchpad branch, but no one even replied, and as a matter of fact no one ever replied to me on Launchpad for any report I issue, so I thought to remove completely ghostscript and install some other version.
At first I thought to add Debian stable repository, and install better tested version, but it turned out that perhaps that's not very good idea - adding Debian repository in Ubuntu.
As I can't "force" Synaptic to some previous GS version (as there is only one it seems - problematic one) I don't know how to approach this problem and wanted to ask how to install previous version, 8.71 preferably, because that's the last version in Debian stable.
Update:
I removed GS 9.01 (and bunch of other packages on the way) and followed Boris' advice, as I didn't know what else can I do.
I installed:
libgs8_8.71~dfsg2-9_i386.deb
ghostscript_8.71~dfsg2-9_i386.deb
and tested GS interpreter and all was working fine.
Now I wanted to put back all those packages removed by GS 9.01 removal, and I needed to first install ghostscript-x:
ghostscript-x_8.71~dfsg2-9_i386.deb
This is where problem begins:
Error:
Breaks existing package 'gsfonts' that conflict: 'gs'.
But the '/home/zetah/gs/ghostscript-x_8.71~dfsg2-9_i386.deb' provides it via: 'gs,gs-afpl,gs-esp,gs-gpl'
I didn't want to brake things so I removed just installed libgs8 and ghostscript and tried to remove gsfonts package (which additionally removed abiword, gnumeric,..) and then install all again.
But I found out that gsfonts is required by ghostscript and installed whenever ghostscript is installed (so ever before being able to install ghostscript-x package).
Now after installing libgs8 and ghostscript, when I try to install ghostscript-x I get:
Error:
Breaks existing package 'ghostscript' that conflict: 'gs'.
It's exactly the same if I try with Ubuntu 10.10 ghostscript 8.71 packages from Launchpad
