When I use the context menu to extract compressed files on PCManFM, I would like it to automatically create a folder and put the extracted files in it, like it used to happen in Nautilus back when I was able to use it, instead of putting all the extracted files in the current folder, which can cause a mess. Is there any way?
I found a nice workaround by creating a desktop entry. Create a file in ~/.local/share/applications named extract.desktop with the following contents:
[Desktop Entry]
Name=Extract to folder
Comment=Extract archive to a folder with the same name
Exec=file-roller -h %F
Terminal=false
Type=Application
Icon=file-roller
StartupNotify=true
MimeType=text/plain;
Now in PCManFM, right click the archive > Open With...
From Other, select Extract to folder
Once you do this, when you right click any archive of the same type you will see the Extract to folder option in the menu.
Notes:
- You will have to repeat the
Open with...action once for each file type - You can right click and extract multiple archives in the same time
- The action will appear in the start menu >
Other. Clicking it will not do any harm - If you use other archive manager than the default File Roller, you will have to modify the desktop entry
ExecandIconentries. See details about entries here
Another solution would be to create an action in PCmanFM-Qt. I used the script for extracting from the Manjaro Wiki and changed the line:
Exec=atool --extract-to=%d %f
to
The first line is to extract here, and the second, extract to folder. You may also want to change the action's name.
From the Manjaro Wiki:
Creating custom actions
Before creating the actions (which are desktop files), first create its directory/folder by copy-pasting the below command in terminal:
mkdir -p ~/.local/share/file-manager/actions“Extract” custom action
Create and edit the action file (extract.desktop) either by using file manager or by issuing these terminal commands one at a time (replace juffed with your text editor if it’s different):
touch ~/.local/share/file-manager/actions/extract.desktop
juffed ~/.local/share/file-manager/actions/extract.desktopPaste the below content in extract.desktop:
[Desktop Entry] Type=Action Name[en]=Extract Icon=package-x-generic Profiles=profile-zero;[X-Action-Profile profile-zero] MimeTypes=application/x-7z-compressed;application/x-7z-compressed-tar;application/x-ace;application/x-alz;application/x-ar;application/x-arj;application/x-bzip;application/x-bzip-compressed-tar;application/x-bzip1;application/x-bzip1-compressed-tar;application/x-cabinet;application/x-cbr;application/x-cbz;application/x-cd-image;application/x-compress;application/x-compressed-tar;application/x-cpio;application/x-deb;application/x-ear;application/x-ms-dos-executable;application/x-gtar;application/x-gzip;application/x-gzpostscript;application/x-java-archive;application/x-lha;application/x-lhz;application/x-lzip;application/x-lzip-compressed-tar;application/x-lzma;application/x-lzma-compressed-tar;application/x-lzop;application/x-lzop-compressed-tar;application/x-rar;application/x-rar-compressed;application/x-rpm;application/x-rzip;application/x-tar;application/x-tarz;application/x-stuffit;application/x-war;application/x-xz;application/x-xz-compressed-tar;application/x-zip;application/x-zip-compressed;application/x-zoo;application/zip;multipart/x-zip; Exec=atool --extract-to=%d %f Name[en]=Default profile SelectionCount==1
This will uncompress the selected archive into the current directory. (You may need to change the icon in the above code if you don't have oxygen icons.)
https://wiki.manjaro.org/index.php?title=PCmanFM-Qt&mobileaction=toggle_view_desktop
