I'm trying to remove a package that records YouTube audio to .mp3 files but can't remember the package name.
I'm using sudo apt-get purge <package name> but I enter the package name incorrectly and then "Unable to locate package" is displayed.
Does anyone know the name of the the package?
Thanks
Jacob
You can do the following using the terminal:
  1. To see all packages and look for the one you installed - dpkg --get-selections | grep -v deinstall
  2. To see a broader list - dpkg -l
  3. Use grep tool to search for the two keywords you mentioned above - dpkg --get-selections | grep [youtube-to-mp3]
If using Ubuntu version greater than 14.04, use apt list --installed.
Then after identifying the package (note: options 1 & 2 will give you large outputs as I saw when I ran it) you can simple do:
For Ubuntu 14.04 and older:
sudo apt-get purge <the-package-name>
For Ubuntu 16.04 and newer:
sudo apt purge <the-package-name>
muru
  • 207,228
George Udosen
  • 37,534
/var/log/apt/ contains log files describing which packages were installed, and when they were installed.
waltinator
  • 37,856
To purge the package in question run:
sudo apt-get purge youtube-to-mp3
David Foerster
  • 36,890
  • 56
  • 97
  • 151
AlexP
  • 10,435
