description of the problem
It seems both wifi and ethernet has the same problem. However, it seems it only happens when the suspend time is long. If I close lid for about 5 min or so, it is OK. However when I suspend for hours, when coming back, I can't connect to the internet. I have tried:
sudo systemctl restart network-manager.service
sudo service network-manager restart
sudo service NetworkManager restart
None of them helps, even log out. The only way to resume the network is by a restart.
I found some post on the web such as this one: Wifi doesn't work after suspend after 16.04 upgrade, but it doesn't help even there are so many vote ups, therefore I think it is OK to ask this question again to draw some attention and hopefully my problem can be solved.
Edit
-> ~$ lspci -knn | grep Net -A2
03:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8188CE 802.11b/g/n WiFi Adapter [10ec:8176] (rev 01)
    Subsystem: Realtek Semiconductor Co., Ltd. RTL8188CE 802.11b/g/n WiFi Adapter [10ec:8195]
    Kernel driver in use: rtl8192ce
Lifted from Wifi doesn't work after suspend after 16.04 upgrade
I found that first researching which ethernet hardware and driver/module I am running, and then removing and reloading that module, did work for me (though it did not for buzhidao):
Wifi:
Ethernet:
$ lspci -knn | grep Ether -A2
The second of these (ethernet) was what I used, and I found:
03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 0c)
        Subsystem: Hewlett-Packard Company RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [103c:1944]
        Kernel driver in use: r8169
        Kernel modules: r8169
so i reloaded the 'r8169' driver:
$ sudo rmmod r8169 && sudo modprobe r8169
and voila! This worked. My ethernet port / connection came back alive (after suspend/wakeup) without having to reboot.
in my case the driver was different, but the same commands rmmod and modprobe did the trick
therightstuff
  • 161
