When I try to launch Black Mesa from steam in Ubuntu, it does not run. When I try to run the game from the terminal, I get this error:
~/.steam/steam/steamapps/common/Black Mesa$ ./bms_linux -game bms +developer 0 -steam
./bms_linux: error while loading shared libraries: libtcmalloc_minimal.so.4: cannot open shared object file: No such file or directory
I am able to play the game on Fedora just fine by launching it in steam, but not Ubuntu. Does anyone know how to install libtcmalloc_minimal.so.4?
Edit:
After installing libtcmalloc-minimal4, I get this error:
./bms_linux: error while loading shared libraries: libtcmalloc_minimal.so.4: wrong ELF class: ELFCLASS64
Edit 2: After installing the 32bit libtcmalloc-minimal4:i386 library, I get these errors:
:~/.steam/steam/steamapps/common/Black Mesa$ ./bms_linux
SDL video target is 'x11'
This system supports the OpenGL extension GL_EXT_framebuffer_object.
This system supports the OpenGL extension GL_EXT_framebuffer_blit.
This system supports the OpenGL extension GL_EXT_framebuffer_multisample.
This system DOES NOT support the OpenGL extension GL_APPLE_fence.
This system DOES NOT support the OpenGL extension GL_NV_fence.
This system supports the OpenGL extension GL_ARB_sync.
This system supports the OpenGL extension GL_EXT_draw_buffers2.
This system DOES NOT support the OpenGL extension GL_EXT_bindable_uniform.
This system DOES NOT support the OpenGL extension GL_APPLE_flush_buffer_range.
This system supports the OpenGL extension GL_ARB_map_buffer_range.
This system supports the OpenGL extension GL_ARB_vertex_buffer_object.
This system supports the OpenGL extension GL_ARB_occlusion_query.
This system DOES NOT support the OpenGL extension GL_APPLE_texture_range.
This system DOES NOT support the OpenGL extension GL_APPLE_client_storage.
This system DOES NOT support the OpenGL extension GL_ARB_uniform_buffer.
This system supports the OpenGL extension GL_ARB_vertex_array_bgra.
This system supports the OpenGL extension GL_EXT_vertex_array_bgra.
This system supports the OpenGL extension GL_ARB_framebuffer_object.
This system DOES NOT support the OpenGL extension GL_GREMEDY_string_marker.
This system supports the OpenGL extension GL_ARB_debug_output.
This system DOES NOT support the OpenGL extension GL_EXT_direct_state_access.
This system DOES NOT support the OpenGL extension GL_NV_bindless_texture.
This system supports the OpenGL extension GL_AMD_pinned_memory.
This system supports the OpenGL extension GL_EXT_framebuffer_multisample_blit_scaled.
This system supports the OpenGL extension GL_EXT_texture_sRGB_decode.
This system supports the OpenGL extension GL_NVX_gpu_memory_info.
This system supports the OpenGL extension GL_ATI_meminfo.
This system supports the OpenGL extension GL_EXT_texture_compression_s3tc.
This system supports the OpenGL extension GL_EXT_texture_compression_dxt1.
This system supports the OpenGL extension GL_ANGLE_texture_compression_dxt3.
This system supports the OpenGL extension GL_ANGLE_texture_compression_dxt5.
This system supports the OpenGL extension GL_ARB_buffer_storage.
This system DOES NOT support the OpenGL extension GLX_EXT_swap_control_tear.
OpenGL: Gallium 0.4 on AMD CAICOS (DRM 2.46.0 / 4.8.0-27-generic, LLVM 3.8.1) 3.0 Mesa 12.0.3 (3.0.0)
GL_NV_bindless_texture: DISABLED
GL_AMD_pinned_memory: DISABLED
GL_ARB_buffer_storage: AVAILABLE
GL_EXT_texture_sRGB_decode: AVAILABLE
AppFramework : Unable to load module engine.so!
Unable to load interface VCvarQuery001 from engine.so, requested from EXE.
Note I am using the following AMD video card with the free graphics drivers:
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Caicos XTX [Radeon HD 8490 / R5 235X OEM]
