From what I understand, the core functions of ntpd have been replaced with timesyncd and timedatectl in that version of Ubuntu, as outlined in the documentation found in the link below:
https://help.ubuntu.com/lts/serverguide/NTP.html
If you run the command timedatectl you'll see data in the following format:
chris@loki:/$ timedatectl
Local time: Wed 2016-11-30 11:18:42 GMT
Universal time: Wed 2016-11-30 11:18:42 UTC
RTC time: Wed 2016-11-30 11:18:40
Time zone: Europe/London (GMT, +0000)
Network time on: yes
NTP synchronized: no
RTC in local TZ: no
I ran the following to disable NTP synchronization:
timedatectl set-ntp 0
But I still wasn't able to change the time, as below:
chris@loki:/$ sudo timedatectl set-time "2015-11-08 07:14:00"
Failed to set time: Automatic time synchronization is enabled
I was only able to update this once I'd gone to Settings > Date & Time and disabled Network Time. Not sure where the config file is for that though to do via cli.
The result:
chris@loki:/$ timedatectl status
Local time: Wed 2016-11-30 11:31:33 GMT
Universal time: Wed 2016-11-30 11:31:33 UTC
RTC time: Wed 2016-11-30 11:31:31
Network time on: no
RTC in local TZ: no
chris@loki:/$ sudo timedatectl set-time "2014-11-08 06:40:00"
Local time: Sat 2014-11-08 06:40:02 GMT
Universal time: Sat 2014-11-08 06:40:02 UTC
RTC time: Sat 2014-11-08 06:40:03
Network time on: no
RTC in local TZ: no
